Assembly magazine
Home
Subscription Customer Service
Online
Industry Headlines
AssemblyBlog
ASSEMBLYtv
Assembly Radio
Web Extras
Buyers Guide
Showrooms
Product Review
How To Guides
Webinar
Ask ASSEMBLY
Calendar of Events
eNewsletter
Current Issue
Cover Story
Features
Departments
Digital Edition
Resources
Archives
Job Search
White Papers
Industry Links
Website Review
E-Cards
Market Research
List Rental
Classified Ads
ASSEMBLY Info
June 2009 BPA Statement
Subscribe
About Assembly
Staff Directory
Advertise
Reprints
2010 Plant of the Year Nomination Form
Look Inside—Foam Is Important
by Austin Weber
December 1, 2009
ARTICLE TOOLS
EmailEmailPrintPrintReprintsReprintsshareShare
Robust chair construction contributes to long-lasting support and adjustability. For example, chairs made with 10 and 12 gauge steel will be able to withstand more heavy-duty use and abuse than products made with fiberglass or plastic.
Foam is another important element to look for when selecting assembly line seating. However, the type of foam used in the construction of a chair is something that’s often overlooked.
Foam is produced with varying characteristics and quality. Some types of foam will break down over time and lose its ability to adequately support a person. Better quality foams will continue to spring back and provide consistent support over time, even when the chair is used by a variety of people, molding itself to each individual’s particular contours.
Design, and the quality of components, materials and construction techniques used in assembly line seating, varies. For example, one leading chair manufacturer uses a self-skinning foam that is contoured to fit the buttocks, the back and neck.
Another company combines a core of high-grade upholstery foam and a tough, thin, pliable, molded polyurethane skin. A beaded texture combined with the polyurethane’s elasticity provides sensory stimulation to end users to combat fatigue and discomfort.
Many industrial seat manufacturers traditionally use polyurethane foam, because it is soft and durable. But, use of new types of biofoam may eventually trickel dow to workstation seating applications.
Recently, some Tier One automotive suppliers, such as Johnson Controls and Lear Corp., started to use a biofoam that is not based on petroleum products. They claim that new seat cushions made from plant-derived materials, such as soybeans, can be more readily recycled than traditional polyurethane.
However, according to Liz White, editor of Urethanes Technology International, a trade magazine based in London, “there is a lot of misleading stuff out there, and [automotive] seat makers are not averse to making us think they're using lots of natural products. The level used is currently very low.”
Polyurethane foam is made from two components: isocyanates and polyols. “Some, but by no means all (at least at present) of the polyol used for flexible foam for seating can be replaced by natural oil polyols,” White points out. “The industry has used many of these for a long time.
“But, the isocyanate content cannot be replaced by natural materials,” adds White. “Hence ‘biofoam' is basically a foam with well under 50 percent (often 5 percent to 10 percent) bio-content. It is still a polyurethane foam, and is recyclable or not in exactly the same way as a standard polyurethane foam.”
Austin Weber
webera@bnpmedia.com
Senior Editor
|PrintEmail
Most Emailed Articles
  1. Welding: Turning on a Spot
  2. Assemblers Harness Wind Power
  3. Wind Turbines Demand Reliable Components
  4. AIA: Actuators Facilitate Automatic Welding
  5. The Pros and Cons of Cells
  6. AGVs vs. Conveyors
  7. Automated Assembly: Get Agile
  8. Robotic Ultrasonic Welding
  9. Mixed-Mode Manufacturing: Software Strategy Is Everything
  10. Automation Profiles: Cabinet Assembly Moves Into 21st Century
Top Searches
  1. Lean Workstation
  2. leak testing
  3. torque
  4. lean
  5. wave solder
  6. Plants
  7. model t
  8. fuel cell
  9. robots
  10. ritter
Most Popular Articles
  1. Mind the Gap 2/20/08
© 2010 BNP Media. All rights reserved. | Privacy Policy
Your Feedback
