Columns
Piezoelectric Feeders Handle Sensitive Parts
In some ways, vibratory feeders have been a victim of their own success. The technology has worked so well, for so long, that few innovative ideas have been introduced.
Until now. Sanki Co. (Nagoya, Japan) has developed vibratory feeders that are driven by piezoelectric resonators rather than electromagnetic coils. A piezoelectric resonator is a fine ceramic of lead titanate and lead zirconate. The resonator warps one way in response to an electric current in one direction, and it warps the other way in response to current in the opposite direction. Each resonator is paired with a leaf spring. Piezoelectric in-line feeders have two resonator-spring pairs. Piezoelectric bowls have three or four.
Distributed in North America by Mirai Inter-Technologies Systems Ltd. (Richmond Hill, Ontario, Canada), Sanki’s piezoelectric vibratory feeders have several advantages over electromagnetic feeders. Piezoelectric feeders consume 70 percent less energy than comparable electromagnetic feeders. They are unaffected by ambient conditions, and they do not generate heat.
Piezoelectric feeders do not subject parts to a magnetic field, which can be important for feeding sensitive electronic components, such as chip capacitors, chip resistors and connectors. In addition, the spring does not require adjustment. Once the feeder is assembled and set to operate at 50 or 60 hertz (depending on the available power), adjusting the resonance spring is unnecessary.
Piezoelectric feeders are shorter than comparable electromagnetic feeders, and a wide range of feed rates can be selected with the voltage control. Because a piezoelectric feeder is driven directly by leaf springs that oscillate at a high rate, the device can feed small, thin parts without jiggling. Piezoelectric feeder bowls can even feed powder.
Besides bowls, a number of in-line feeders are available. The smallest in-line feeder weighs 0.25 kilogram. The largest weighs 17 kilograms with a maximum chute weight of 5 kilograms and a maximum chute length of 700 millimeters.
Direct-mounted in-line feeders are the simplest of the in-line models and produce the highest feed rates. However, because the reactive force is directly transmitted to the mounting frame, this type of feeder should be limited to compact systems.
Alternatively, the in-line feeder can be installed between the drive unit and the mounting frame via an intermediate spring. This reduces the reactive force applied to the frame. These feeders handle medium-sized and large parts with minimal vibration.
A third type of in-line feeder is mounted to rubber support legs. This significantly reduces the reactive force, so that the feeder can be used on a standard desk top. It can be used for high-speed feeding of medium-sized and large parts.
For more information on piezoelectric feeders, call Mirai Inter-Technologies at 905-763-9442 or visit www.miraiintertech.com.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
