Columns
Assembly In Action: Supplier Assembles Car Parts on Conveyor
Plastics manufacturer Dr. Franz Schneider Kunststoffwerke (Kronach, Germany) is an automotive supplier and producer of plastic components. The company specializes in func- tional trim elements, such as fresh- air grills, produced using various injection-molding processes.
When BMW (Munich, Germany) gave the go-ahead for development and production of the new 3 Series, a more powerful and flexible assembly system would have to replace the company's then current production methods. The demands placed on the new assembly system were high. It had to link manual workstations with automated production and guarantee maximum productivity.
After investigating transfer systems, the facility planners chose the MTS 2 modular transfer system from Bosch Automation Technology (Buchanan, MI). Assembly equipment for the manual workstations was also inte-grated smoothly into the new assembly system.
The MTS 2 links 13 station modules, of which 10 stations are designed for manual work. Sixty workpiece pal- lets, 30 for the left-hand grill and 30 for the right-hand, travel through the assembly system. The pallets are equipped with a data tag that records the entire routing plan. The data tag ensures that the workpiece automa-tically takes the proper path within the transfer system and stops only at the station in which the next assem- bly step is scheduled.
Each fresh-air grill consists of 36 individual parts. Eight manual stations were provided in the production line for the louvers. At stations one through four, two identically equipped workstations mount the vertical louvers for the left- and right-hand grills. Corresponding X pallet distribution--one of the basic functions of the MTS 2--ensures uniform loading of the parallel workstations.
Horizontal louver assembly is performed at four manual workstations. Assembling the components, which are coated with special water-based paints, requires dexterity. After a worker inserts the louvers into an assembly apparatus, they are snapped into place with a connecting rod and covered with the upper part of the housing.
Prior to processing, each worker checks that the arriving workpiece is complete. Improperly assembled workpieces are sent back for repair. The MTS 2 controller ensures that the workpiece pallet is returned to the specific station responsible for that error.
The fully assembled halves of the housing, still loosely stacked, continue in the transfer system. At the next two automated stations, two ultrasonic welding machines permanently join the upper and lower halves before imprinting.
The imprinting of all fresh-air grills by a stamp-print process occurs at a common station. Using a specially designed workpiece pallet allows centering the print head and printing the left- and right-hand grills simultaneously. A light barrier at the station entrance generates the signal to load the print head with fresh paint prior to each printing operation. A warm-air blower dries the paint, and the grills leave the station at 7-second intervals.
The left- or right-hand grill proceeds to final assembly via the corresponding outfeed module. The air flap and bevel gear are mounted. After a successful final check, two seals are mounted, and the grills are placed into a sectioned container.
For more information on con- veyor systems, call Bosch Automation Technology at 800-322-6724, visit www.bosch.com.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
