Loctite Studies New Materials for Fuel Cells
ROCKY HILL, CT--Loctite Corp. is developing specialty materials for assembling automotive fuel cells.
Fuel cells generate electricity through an electrochemical exchange between oxygen and hydrogen. The devices have long supplied electricity on spacecraft and are becoming the favored backup source in electric power plants. Now, the cells are poised to become the automotive power source of the future.
Fuel cells are comprised of tightly compressed stacks of 12-inch by 12-inch carbon plates, which function as bipolar anode and cathode electrodes. The plates are sandwiched between polymer proton exchange membranes. The bigger the stack, the more power is generated. Three-hundred fuel cells in a stack generate approximately 50 hp.
Hydrogen is fed into one side of the membrane and oxygen from the opposite side. Platinum coating on the membrane catalyzes these gases, releasing free electrons and protons. The electrons form the cell's electrical output, which is transmitted through an external circuit to power the vehicle. Protons migrate through the membrane where they are combined with oxygen and expelled through the tailpipe as harmless water and heat.
Tight, reliable, fail-safe sealing is critical to cell performance, says Joe Ballantine, director of automotive marketing at Loctite. "All of these new power sources will require specialty adhesives, sealants and coatings to enable them to function reliably and efficiently," he says. "Loctite intends to be the primary supplier of these materials."
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
