Columns
Assembly in Action: Thread-Forming Fasteners Deny Rejects
By switching to a 25-millimeter thread-forming fastener designed for magnesium applications, DaimlerChrysler virtually eliminated screw fault rejects and reduced process time in assembling steering columns.
"Both the tilt head and the main body of the steering column are made from die cast magnesium," says Mark Laws, product and quality engineering supervisor at Toledo Machining (Toledo, OH). "Magnesium is lighter than steel or aluminum, easier and less expensive to process and machine, and has good fatigue strength, dimensional stability, and sound and vibration dampening qualities."
"However," Laws says, "its ductility is low and is easily deformed. This can lead to slivering, layer eruption, chipped threads and fracturing using standard threaded fasteners. Removing and reinserting these fasteners can weaken or destroy threads, creating magnesium powder, debris and contamination."
To meet this challenge, engineers at Toledo Machining selected Camcar brand Mag-Form thread-forming fasteners from Textron Fastening Systems (Belvidere, IL) to join the lower mounting bracket to the cast magnesium body of the steering column. The fasteners are compatible with existing assembly equipment, in which two fasteners form threads as they are driven into cored magnesium holes.
Mag-Form fasteners were engineered to eliminate tapping operations in magnesium materials with minimal debris generation and good serviceability.
These fasteners have lobe-shaped steel threads with a wide pitch and a broad, 105-degree flank angle that compresses, rather than roll-forms threads into mating material. This reduces shear stresses and increases compression, allowing magnesium to deform to create the thread rather than being cut. The result is a good fastener joint. There is virtually no magnesium thread damage, and torque values are consistent. The fastener can also be removed and reinserted multiple Arial in service.
Since going on-line, more than 1.5 million Mag-Form thread-forming fasteners have been installed on steering columns. The 40 percent cycle time reduction saves hundreds of hours and thousands of dollars annually.
For more information on thread-forming fasteners, call 815-544-7521 or visit www.textronfasteningsystems.com.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
