Columns
Assembly in Action: Tool Changers Play Central Role
Central to Chrysler’s lean conversion has been the ability to equip its robots with automatic tool changers, so that the company can quickly and reliably change out end effectors.
By employing automatic tool changers on its robots, Chrysler Group is able to build three different vehicle models on a single line at its Belvidere, IL, assembly plant.
In recent years, Chrysler Group (Auburn Hills, MI) has placed increasing emphasis on flexibility in order to compete in a tough global market. In particular, the company has committed itself to reconfiguring its newer assembly processes so that it can build multiple product types on a single line.
Central to this effort has been Chrysler’s ability to equip many of its robots with automatic tool changers, so that they can quickly and reliably change out their end effectors.
For example, at its recently upgraded assembly plant in Belvidere, IL, Chrysler installed approximately 700 robots from ABB Ltd. (Zurich, Switzerland) and 237 master-side and 576 tool-side heavy automation tool changers from ATI Industrial Automation (Apex, NC). In operation, the master-side tool changers are installed at the end of the company’s robotic arms, while the tool-side “plates” are attached to various different end effectors, including everything from grippers to welders. The robots use this tool-side component, which can include routing for everything from I/O to hydraulic fluid to compressed air, to both pick up and manipulate the different tools.
Thanks to this increased flexibility, the Belvidere assembly line currently assembles three different vehicle types-the Dodge Caliber, the Jeep Compass and the Jeep Patriot. As an added bonus, the plant’s recent refit cost Chrysler Group about 30 percent less than it would have in the past, in part because it was able to reuse a substantial amount of existing equipment.
“We are now starting to see the results of the flexible manufacturing process that we believe is a competitive advantage,” says Frank Ewasyshyn, executive vice president of manufacturing at Chrysler Group. “Thanks to Belvidere’s ability to build multiple models off one assembly line, we expect the production of three all-new models to cost significantly less than the initial investment we made in the plant to build one product.”
Automatic tool changers are available in a number of sizes and models, which handle both large and small payloads. The ATI line, in particular, employs a double-taper locking piston in combination with two locating pins to provide high-cycle performance and repeatability. An integrated locking mechanism ensures that the tool-side plate remains attached to the robot, even in the event of pneumatic pressure loss. Different electrical, pneumatic and fluid modules are available to accommodate a wide range of applications.
For more on tool changers, call 919-772-0115 or visit www.ati-ia.com.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
