The FDA should develop a new regulatory
framework to replace the 510(k) clearance process for moderate-risk medical
devices, advises a report issued July 29 by the Institute of Medicine.
The U.S. Food and Drug Administration should develop a new regulatory
devices, advises a report issued July 29 by the Institute of Medicine (IOM).
According to the report, the 510(k) process lacks the legal basis to be a
reliable premarket screening tool for the safety and effectiveness of Class II
devices and cannot be transformed into one.
An independent, nonprofit advisory organization, the IOM believes the FDA would
be better off developing a new framework that uses both premarket clearance and
better postmarket surveillance to provide reasonable assurance of the safety
and effectiveness of Class II devices. The FDA should also ensure that the new
process allows devices to reach the market in as rapid and least burdensome a
fashion as possible.
The 510(k) clearance process was devised to provide a more expedient way to
evaluate Class II devices than the more rigorous premarket approval (PMA)
process that high-risk Class III devices must undergo. Unlike the PMA process,
which requires manufacturers to submit results of safety and efficacy tests,
the 510(k) process relies on “substantial equivalence”-determining if new
devices are sufficiently similar to comparable products that have been previously
cleared or were on the market prior to 1975, when the 510(k) process was enacted.
The IOM report concluded that reliance on substantial equivalence cannot assure
that Class II devices are safe and effective, since most devices used as the
basis for comparison were never reviewed for safety or effectiveness. This does
not mean that they or the devices that followed them are unsafe, and the report
notes that continued use of these products in clinical practice should provide
a level of confidence in their safety and effectiveness.
“It’s not clear that the 510(k) process is serving the needs of either industry
or patients, and simply modifying it again will not help,” says David
Challoner, chairman of the IOM committee that wrote the report. “The 510(k)
process cannot achieve its stated goals-to promote innovation and make safe,
effective devices available to patients in a timely manner-because they are
fundamentally at odds with the statutes that govern how the FDA must implement
the process.”
Medical device assemblers were quick to criticize the report. “We completely
disagree that the 510(k) pathway is ‘flawed’ and that the FDA needs to
eliminate it,” says Mark Leahey, president and CEO of the Medical Device
Manufacturers Association. “Studies prove the 510(k) process has a strong track
record on patient safety, and a complete overhaul of the system is simply not
warranted.”
“The report’s conclusions do not deserve serious consideration,” adds Stephen
J. Ubl, president and CEO of the Advanced Medical Technology Association. “It
proposes abandoning efforts to address serious problems with the administration
of the current program by replacing it at some unknown date with an untried,
unproven and unspecified new legal structure. This would be a disservice to
patients and the public health.”
Indeed, the IOM report does not specify what a new framework should entail.
However, it does advise the FDA to explore whether a modified version of its de
novo process could replace the 510(k) process. The de novo process reduces the
amount of information manufacturers must supply for devices deemed to be of low
or moderate risk, but that have no predicate devices against which to be
compared.
To download a copy of the report, visithttp://iom.edu.
