How-to-Guide
How To Convert a Two-Line Vacuum System to a Single-Line Operation in 5 Easy Steps
How do I reduce air consumption, provide cost savings, and increase productivity? DE-STA-CO, a global manufacturer of industrial automation and workholding solutions, answers that question with the launch of its complete line of Auto-Release Venturi products.
DE-STA-CO, a global manufacturer of industrial automation and workholding solutions, answers that question with the launch of its complete line of Auto-Release Venturi (ARV) products.
The typical two-line or centralized vacuum system requires the use of two air lines, one for “air-in” supply to generate vacuum, and the other for blow-off to release the part.
The ARV requires just one line, a supply “air-in” line for vacuum. The ARV features an atmospheric vent for instant part release, and an integrated silencer for quiet operation (less than 70dB). These features save time and money by offering the following benefits:
• Faster Production Speeds
• 150+ cycles per minute
• 60% less air consumption (reducing cost and carbon emissions)
• Reducing operator fatigue.
The ARV was designed to fit into existing plumbing without the cost of additional components.
Let us show you how to convert your vacuum system in five easy steps.
From a two-line system using venturi with blow-off
Step 1 Locate blow-off air-line.
Step 2 Disconnect/remove air line and plug blow-off port.
Step 3 Disconnect/remove existing venturi and replace with ARV.
Step 4 Reconnect air line to ARV.
Step 5 Verify operation.
From a Centralized Vacuum System (CVS)
Step 1 Locate CVS/vacuum generator and remove from system.
Step 2 Install tow Position Valves, connect to air supply and plug blow-off port.
Step 3 Disconnect/remove existing port-only adaptor and replace with ARV.
For Clean Room Applications
Class 10 Clean Room Approved
• 1-2 particles per cubic meter of air (M3)
• Auto blow-off prevents contamination
• Remote exhaust port delivers exhaust outside of clean room
• Clean room air used for part release
• Vacuum port removes debris/self cleaning
• Hassle-free installation: SCARA 50-millimeter bolt circle
For Porous and Textured Products
Increased Vacuum Flow
The Multi-Flow ARV is offered with either a medium or high-flow cartridge, designed to be used for:
• Handling porous products
• Products with textured surfaces
• General industry
Available with apple core or remote “block” style mounting.
For more information, please visit our web site at www.destaco.com or email us at marketing@destaco.com.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
Lighting and 3D: Their Impact on Vision Inspection
Cognex Corp. makes vision inspection systems for manufacturers worldwide. Recently, John Stamos, sales engineer for Cognex, spoke with Jim Camillo, a senior editor of Assembly magazine, about the impact of lighting and 3D technologies on current and future vision inspection systems. The interview was conducted after a small-group presentation by Stamos in Chicagoland.
More Podcasts
THE MAGAZINE
Assembly Magazine
February 2012 issue cover
2012 February
Assembly's new issue is now available. Check it out!
TABLE OF CONTENTS SUBSCRIBE
U.S. manufacturers
What are your plans for 2012?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn
