Assembly in Action / Automotive Assembly / Workstations Assembly / Columns
Assembly In Action: LED Lighting Brightens Floor, Finances at Metal Parts Plant
Spanish manufacturer Martisa produces metal parts for the automotive industry at its Barcelona plant. However, the plant, which measures 1,288 square meters, has experienced various lighting problems the past several years.
The facility’s 32 400-watt high-pressure sodium (HPS) lights often flickered and dimmed due to energy surges caused by the plant’s metal processing machinery. The HPS lights produced inconsistent lighting throughout the plant; illuminance varied from 118 to 270 lux at floor level. Also, the lights took 10 minutes to re-strike following power outages, negatively impacting productivity.
Maintenance was also a challenge, as the HPS lights were mounted at a height of 9 meters, ran 10 hours a day five days a week, and had to be replaced every 10,000 hours. Each replacement light cost 50 euro, while the mobile elevation platform required to install the light cost 100 euro per day.
Looking to create better and more even lighting—as well as save energy—company executives met with energy consultant Area Energetica, which is a partner of lighting distributor Inelec. Area Energetica recommended replacing the HPS lights with DuroSite LED High Bay lights made by Dialight Corp.
DuroSite LED High Bays are 150-watt lights that are L7 rated to last 80,000 hours and maintain 80 percent luminance after 60,000 hours. The lights produce minimal heat with no ultraviolet light or infrared radiation. They also require no maintenance, come with a 5-year continuous performance warranty and are mercury-free.
DuroSite lights are mounted at the same height as the HPS lights, but they provide consistent luminescence of 200 lux at floor level. Martinez says DuroSite lights also switch on and off instantly to improve lighting efficiency and reduce re-strike time following power outages.
The new lights have reduced Martisa’s lighting energy use by 69 percent, from 9.9 watts per square meter to 3.7 watts. The lights have also reduced the plant’s carbon emissions.
Each fixture weighs 17 pounds and features a housing made of copper-free, powder-coated aluminium. IP6-rated, the housing is designed to withstand dust and moisture. The fixture can be equipped with an acrylic, polycarbonate or tempered flat lens, or a polycarbonate dome lens.
For more information on LED lights, call 732-919-3119 or visit www.dialight.com.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
