How-to-Guide / Assembly Presses / Screwdriving and Riveting Assembly
advertisement
How To Properly Pin a Shaft and Hub Assembly
March 5, 2014
Trans
One of the primary benefits of using a Coiled Pin to affix a hub or gear to a shaft is the Coiled Pin’s ability to prevent hole damage. There are a few basic design guidelines that must be adhered to in order to achieve the maximum strength of the pinned system and prevent damage to the assembly:
The design guidelines can be divided into two groups: 1) the shaft and hub, and 2) the pin.
1. Shaft and Hub Considerations
The hole in a shaft should not exceed 1/3 of the shaft diameter.  For mild steel and nonferrous shafts, standard duty pins are recommended.  The extra strength of a heavy duty pin is only beneficial if the hole is less than 1/4 the diameter of the shaft or if the shaft is hardened. (Figure 1)
It is recommended that the hub be designed with a minimum wall thickness of 1.5 times the diameter of the pin.   Otherwise, the strength of the hub will not match the shear strength of the pin. (Figure 1)
Installing a cylindrical pin into a hole on the surface of a cylindrical object leads to two point contact between the pin and the hole. This concentrates the compression force on only two points of the circumference. To increase the contact surface between the periphery of the hole and pin, and to ease installation, a flat should be placed on the exterior surface of the hole. (Figure 2)
Countersinks on the holes are not recommended.  In addition, the outer diameter of the shaft (OD) and the inner diameter of the collar (ID) should be designed such that the distance between the shear planes (OD-ID) does not exceed .005” (0.13mm).  In both cases, an unsupported length of pin in an area where torque may be applied is created.  This could cause a bending moment, which shortens the lifespan of the pin.
The hole should be centered in both the shaft and hub to prevent stress concentration and ensure there is enough material around the pin to withstand the applied forces.
It is recommended that the difference between the hole diameters in the hub and shaft not exceed .002” (0.05mm) to prevent movement of the parts relative to each other. Otherwise, the pin will be subject to dynamic loading such that a very small change in velocity could equate to a significant change in force impacting the assembly.
If the holes cannot be precision matched, dividing the tolerance between the shaft and hub is recommended. The larger half of the tolerance should be applied to the component with the longest engagement length, and the smaller half should be applied to the other component.
2. Coiled Pin Considerations
It is important to start with the load to which the pin will be subjected.  Then evaluate the material of the host to determine the duty of the Coiled Pin.  The pin diameter needed to transmit the load in the proper duty can then be determined from the shear strength tables in a Coiled Pin product catalog.
Standard duty Coiled Pins have the optimum combination of strength and flexibility for use in nonferrous and mild steel components. They are also recommended for use in hardened components as they have greater shock absorbing capabilities.
Heavy duty pins should only be used in hardened materials where space or design limitations rule out a larger diameter standard duty Coiled Pin.  An exception to this rule is that austenitic (nickel) stainless steel pins should never be used in hardened components.
A light duty pin is recommended for soft, brittle or thin materials or where holes are close to an edge.  In situations not subject to significant loads, light duty pins are often used because of the lower insertion forces required.
Although this article offers general design guidelines, it is recommended that Application Engineers who specialize in fastening and joining be consulted to ensure the optimum design is employed for each application.
 For technical assistance please visit www.spirol.com/s/am-spring/ or call SPIROL at 860-774-8571.
Multimedia
Videos
Image Galleries
Podcasts
 Live from The ASSEMBLY Show, Bob Wood, president of ECI Spinnomatic, talks about his company’s newest product: a fully automated riveting cell equipped with a rotary indexing table, a six-axis robot, an orbital forming unit, and laser sensors.
More Podcasts
Assembly Magazine
february cover
2015 February
The 2015 February Assembly includes our cover story Delta Robots Feed Need for Speed plus much more. Check it out today!
Table Of Contents Subscribe
Supplier Poll
How important is geography when you’re looking for a supplier?
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
STAY CONNECTED
Assembly Showrooms
ASSEMBLY Showrooms
