Columns
Assembly in Action: Moving From Manual Welding to Automated
March 1, 2001
Skill Tool & Die (Cleveland, OH) set a goal of producing a spare tire bracket more efficiently and with better quality. Achieving this goal required streamlining the job from manual welding to a fully automated welding operation. According to John Kun, vice president of engineering and technology, "The manual process produced inconsistent welds, which resulted in a part that was not visually appealing."
The bracket consists of three individual pieces that are joined together and welded in a multitude of spots. Due to the part's size and required fixturing, a single-point, stationary spot welder would not suffice. Because of the cycle time and space constraints, a robot would not lend itself to this application. Extensive handling labor and cycle time were unacceptable. However, the company wanted guaranteed quality and consistency for each spare bracket.
MIM Industries Inc. (Miamisburg, OH) met the challenge with a dual-station machine that automatically produces all 23 welds. This programmable machine operates in three axis of motion and has multiple weld heads that can be activated anytime during the cycle.
By incorporating dual weld stations with fixtures that move on an X-Y-Z axis, process time was reduced, and only one operator is needed to run the machine. Each station is programmed via the operator interface using a teach method principle of point to point. Additionally, this programming flexibility allows part design changes during the product's life cycle.
The new welding machine incorporates several sensors to ensure that the subcomponents are in the correct position prior to cycle start. It also utilizes a sophisticated interface to control the required motions and weld process. In addition to the high-tech components, the spare tire bracket welder is simple enough for any operator to learn with minimal training.
For more information on welding stations, call MIM Industries Inc. at 937-866-4478
  • Assembly in Action: Manufacturer Moves From Manual Welding to Automated
  • Assembly in Action: Switching to Automated Marking Boosts Productivity
  • Assembly In Action: Welding Machine Benefits From Controls Upgrade
  • October 30, 2025
  • June 12, 2025
    From Manual Data to ISO 9001 in 6 Months: How Lithos Energy Did It
    On Demand How does a fast-growing battery manufacturer move beyond paper travelers to a digital ecosystem that drives better quality, real-time traceability, and faster audits?Sponsored by:
  • Automated Assembly Corp.
  • HAHN Automation Group US Inc.
    HAHN Automation Group is your global solution partner for factory automation. We offer industry-specific know-how, an extensive project portfolio, and global organization--all from a single source. From manual stations to semi-automated cells and full production lines, we provide custom solutions to manufacturers in automotive, medtech, and electronics industries worldwide.
