Auto-Kabel, the global automotive supplier, manufactures cable and lead sets for power supply applications. The friction welding machines deployed in the process must always have an adequate supply of material without excessive safety stocks.
Companies measure success in several ways. One of the most important measurements is their number of repeat customers. For wire harness shops, the best way to gain repeat customers is to provide them an ongoing supply of harnesses that are high quality, economical and specifically designed to meet each application challenge.
Ergonomic mats can reduce the risk of injury and absenteeism in applications that require prolonged standing
October 9, 2018
The statistics relating to musculoskeletal conditions are frightening. In 2012, one of every two adults in the U.S. were diagnosed with some form of musculoskeletal disorder leading to 290.8 million work days lost due to back or neck pain.
Ensuring high quality is relatively easy when all you have to do is assemble one small product at a very high volume. Such an item will likely be produced on a high-speed automated assembly system. Assuming there are no issues with the incoming parts, the system will consistently produce perfect assemblies all day long.
MCPc is an information technology and logistics services company that helps businesses select, deploy, manage and recycle computers and other electronic devices.
A little positive feedback at work can go a long way toward improving assemblers' long-term mental health and well-being. Engineers at the VTT Technical Research Centre of Finland and the European Factory2Fit research consortium are studying the effects of work performance.
Parts come in all sizes, shapes and weights. But, any type of part isn't good until it's at the right location, at the right time and at the right height on assembly lines.
Sometime in 2020, the Solar Orbiter satellite will begin its several-year journey after being launched from the Cape Canav-eral Air Force Station in Florida with an Atlas V rocket.
