Home » Topics » Industries » Aerospace Assembly
Aerospace Assembly
Aerospace Assembly RSS Feed RSS
Selecting Retaining Rings
Consider several technical factors to ensure that the right type of retaining ring is used in each fastening application
Henry Yates
October 3, 2019
Engineers are challenged daily to come up with economical product designs that reduce weight, size, raw materials and labor. This competitive mandate affects every design facet, including the fasteners needed to hold components in place.
Aerospace Parts Maker Uses Clips, Latches to Reuse Boxes
September 17, 2019
Manufacturing high-quality aluminum parts for the aerospace industry presents one set of challenges. But, shipping them safely presents a much different set.
How to Calculate Fatigue Life of Disc Springs
For a given load, engineers can calculate the minimum fatigue life for disc springs
John Leckfor
September 13, 2019
Disc springs are conically shaped, washer-like components designed to be axially loaded.
Virtual Templating with Laser Projection
Laser projection allows companies to speed up welding processes, minimize the use of templates and tools, eliminate errors, and improve quality
Alberto Castiglioni
September 12, 2019
For basic welding jobs, companies often rely on blueprints, tools and tape measures to build and weld the parts. However, when using these conventional tools, there's a high risk of mistakes being made and, at the end, having to break the parts loose, which is expensive and time consuming.
Raytheon-900
Raytheon to Expand Texas Assembly Plant
September 10, 2019
MCKINNEY, TX—Raytheon will build a 200,000-square-foot assembly plant here, supporting 500 new high-tech jobs at its Space and Airborne Systems headquarters. Construction will be completed in late 2020.
Air Force lab takes 3D printing to new heights.
Air Force Lab Takes 3D Printing to New Heights
September 6, 2019
Additive manufacturing is transforming the way many types of products are designed and assembled. One industry that's benefitting the most is aerospace, which traditionally requires complex, low-volume components that must withstand rigorous operating conditions.
Robots for Handling Heavy Loads
Big six-axis machines are an increasingly common sight on factory floors
September 5, 2019
Robotics and wrestling have a lot in common. Flexibility and reach are important to both. Robots and wrestlers also have numerous categories that are based on different weight and payload capacities.
Just-Launched German Company Will Revive Production of Dornier 328 Aircraft
September 3, 2019
LEIPZING, Germany—A new aircraft manufacturer, called DRA, has been launched to develop an updated version of the Dornier 328 aircraft, known as the D328NEU.
Toyota 8-21
Toyota’s Latest Vehicle Really is Out of This World
August 20, 2019
TOKYO—The Japan Aerospace Exploration Agency and Toyota Motor Corp. recently formalized a three-year joint research agreement for the development of a manned, pressurized lunar rover. The vehicle will utilize fuel cell electric vehicle technologies.
Airbus Launches A220 Production at Alabama Assembly Plant
August 13, 2019
MOBILE, AL—Airbus has begun manufacturing A220 aircraft at its assembly plant here, a key milestone in growth plans that will see the company add a second assembly line and hire more than 400 new workers at the site.
Previous 1 2 … 34 35 36 37 38 39 40 41 42 … 104 105 Next
