Torque control is a core process that is often vital to a successful manufacturing strategy. However, fasteners can be a significant source of poor quality and scrap that negatively impacts production.
Two of the biggest trends in the auto industry today are flexible production systems and electric power. And while at first glance they may seem to have little in common, the truth is that the underlying technologies needed to implement both are, in many cases, identical.
With a workforce numbering 320 spread across the globe, INGUN produces test probes and customized and non-customized test fixtures for use in testing equipment in the electronics industry, where they are needed to test the various functions of electronic printed circuit boards.
There are several different ways to move something in a straight line. It's important to understand all the options and choose the best solution for your application.
You are up against extreme space limitations with little room for fitting an air cylinder into your current design project. Here's a few questions and pictures to help point the way to your solution.
Obeyas are all over manufacturing in 2018. For manufacturers that have done their homework, an Obeya is a powerful resource the gels seamlessly with process improvement, but manufacturers that believe an Obeya is just a set of walls and some whiteboards will be sadly mistaken; there's more to an Obeya than just creating a room.
