<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/">
  <channel>
    <title>Product Reviews</title>
    <description>
      <![CDATA[In-depth profiles of the latest assembly technologies.]]>
    </description>
    <link>https://www.assemblymag.com/rss/2700</link>
    <language>en-us</language>
    <item>
      <title>Cordless Power &amp; Mobility</title>
      <description>
        <![CDATA[Get mobile with DEPRAG Cordless EC Screwdrivers:]]>
      </description>
      <guid>http://www.assemblymag.com/articles/89746</guid>
      <pubDate>Wed, 01 Feb 2012 00:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/89746-cordless-power-mobility</link>
    </item>
    <item>
      <title>Portable Inspection of Leading Edge Radius</title>
      <description>
        <![CDATA[
	The LaserGauge&reg; HS733LE sensor is used to inspect the edge radius and thickness of blades during the manufacturing process.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89745</guid>
      <link>https://www.assemblymag.com/articles/89745-portable-inspection-of-leading-edge-radius</link>
    </item>
    <item>
      <title>ViCATS-Visual Control And Test System Leak and flow testing products  </title>
      <description>
        <![CDATA[
	Incorporates a graphical user interface that simplifies and enhances operator and test application interfacing especially when performing such system functions as:</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89744</guid>
      <link>https://www.assemblymag.com/articles/89744-vicats-visual-control-and-test-system-leak-and-flow-testing-products</link>
    </item>
    <item>
      <title>DTI Screw Dispenser from Design Tool Inc.</title>
      <description>
        <![CDATA[The DTI Screw Dispenser from Design Tool is designed to load a pre-determined number of fasteners into a cup and drop them into your hand.</p>]]>
      </description>
      <guid>http://www.assemblymag.com/articles/89743</guid>
      <link>https://www.assemblymag.com/articles/89743-dti-screw-dispenser-from-design-tool-inc</link>
    </item>
    <item>
      <title>Kitting Carts increase productivity</title>
      <description>
        <![CDATA[Solve the identification and rapid retrieval challenges of kitted parts at assembly points using kitting carts custom designed and built with the Creform&reg; System of pipes and joints.</p>]]>
      </description>
      <guid>http://www.assemblymag.com/articles/89742</guid>
      <link>https://www.assemblymag.com/articles/89742-kitting-carts-increase-productivity</link>
    </item>
    <item>
      <title>Ultrasonically Splice 100 mm2 Wire Bundles with Just One Hit</title>
      <description>
        <![CDATA[
	Only Sonobond Ultrasonics&rsquo; units splice 100 mm2 wire bundles, and weld tinned or oxidized wires and sheet metal, creating solid-state metallurgical bonds with high conductivity, in just one pulse.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89741</guid>
      <link>https://www.assemblymag.com/articles/89741-ultrasonically-splice-100-mm2-wire-bundles-with-just-one-hit</link>
    </item>
    <item>
      <title>SPIROL Ground Hollow Dowels for Precision Alignment</title>
      <description>
        <![CDATA[
	SPIROL&reg; Series GD100 Ground Hollow Dowels are designed to be direct replacements for Ground Solid Dowels per ISO 8734 when used in alignment applications.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89740</guid>
      <link>https://www.assemblymag.com/articles/89740-spirol-ground-hollow-dowels-for-precision-alignment</link>
    </item>
    <item>
      <title>ERS Electric Transducerized Screwdriver</title>
      <description>
        <![CDATA[
	Innovative, quality and superior ergonomics all describe this new exciting Transducerized screwdriver by Desoutter. ERS tool features: programmable reverse button, extended lever option, 4 reporting LEDs (2 programmable), head lights, tapered durable soft rubber grip accommodates all operators comfortably.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89739</guid>
      <link>https://www.assemblymag.com/articles/89739-ers-electric-transducerized-screwdriver</link>
    </item>
    <item>
      <title>LM Series Actuator</title>
      <description>
        <![CDATA[
	The RACO LM Series is a lightweight positioning actuator, which can be easily configured into a wide variety of multiple axis motion systems.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89738</guid>
      <link>https://www.assemblymag.com/articles/89738-lm-series-actuator</link>
    </item>
    <item>
      <title>Precision Zero Backlash In Compact Design</title>
      <description>
        <![CDATA[
	RY series, the newest addition to the RollerDrive &reg; family.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89737</guid>
      <link>https://www.assemblymag.com/articles/89737-precision-zero-backlash-in-compact-design</link>
    </item>
    <item>
      <title>New Compliant Utility Couplers</title>
      <description>
        <![CDATA[
	ATI Industrial Automation has developed a new series of Compliant Utility Couplers for automation applications where there is a need to change utilities such as fluid, air and electrical signals.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89736</guid>
      <link>https://www.assemblymag.com/articles/89736-new-compliant-utility-couplers</link>
    </item>
    <item>
      <title>Increase Productivity with Eraser’s Wire Processing Equipment</title>
      <description>
        <![CDATA[
	Eraser&rsquo;s DCF Series strips magnet and enamel wire from 35 - 9 AWG.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89735</guid>
      <link>https://www.assemblymag.com/articles/89735-increase-productivity-with-eraser-s-wire-processing-equipment</link>
    </item>
    <item>
      <title>High-Speed Pick &amp; Place with Precision</title>
      <description>
        <![CDATA[
	The PPU-E30 has a cycle time of 0.58 seconds including switching and gripping times at a 40 mm vertical stroke, a 120 mm horizontal stroke, and a moving mass of 2 kg.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89734</guid>
      <link>https://www.assemblymag.com/articles/89734-high-speed-pick-place-with-precision</link>
    </item>
    <item>
      <title>Bag &amp; Box Grippers</title>
      <description>
        <![CDATA[
	Palletizing &amp; Packaging End-of-Arm Tooling (EOAT) for all makes of robots.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89733</guid>
      <link>https://www.assemblymag.com/articles/89733-bag-box-grippers</link>
    </item>
    <item>
      <title>Tri-Star’s New Mold-In Precision Brass Inserts</title>
      <description>
        <![CDATA[
	Designed for molding into plastics, rubber and ceramics. MC-Series inserts have a &ldquo;closed-end&rdquo; bottom, preventing plastic flow into the threads.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89730</guid>
      <link>https://www.assemblymag.com/articles/89730-tri-star-s-new-mold-in-precision-brass-inserts</link>
    </item>
    <item>
      <title>Vision Aided Feed System</title>
      <description>
        <![CDATA[Performance Feeders has utilized a variety of camera vision systems in order to reliably orient parts with internal differences that a standard bowl feeder could not previously do.</p>]]>
      </description>
      <guid>http://www.assemblymag.com/articles/89729</guid>
      <link>https://www.assemblymag.com/articles/89729-vision-aided-feed-system</link>
    </item>
    <item>
      <title>Sprinter Model 88</title>
      <description>
        <![CDATA[
	Sprinter Model 88 ink code-marking machine for date, product, lot and dot coding applications.</p>
      </description>
      <guid>http://www.assemblymag.com/articles/89728</guid>
      <link>https://www.assemblymag.com/articles/89728-sprinter-model-88</link>
    </item>
    <item>
      <title>Paste Brazing &amp; Soldering Alloys</title>
      <description>
        <![CDATA[Fusion Paste Alloys deliver all the ingredients for a strong, void-free brazed or soldered joint in one deposit.</p>]]>
      </description>
      <guid>http://www.assemblymag.com/articles/89727</guid>
      <link>https://www.assemblymag.com/articles/89727-paste-brazing-soldering-alloys</link>
    </item>
    <item>
      <title>Aven Inc.-Mighty Scope Aids Medical Device Design, Assembly</title>
      <description>
        <![CDATA[Aven introduces a compact digital microscope for medical device engineering, precision manufacturing and quality control inspections.      ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/89395</guid>
      <pubDate>Fri, 18 Nov 2011 12:54:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/89395-aven-inc-mighty-scope-aids-medical-device-design-assembly</link>
    </item>
    <item>
      <title>Sealant Equipment &amp; Engineering-Servo-Flo 704 Meter-Mix Dispense System Improves Product Quality</title>
      <description>
        <![CDATA[The Servo-Flo 704 two-part dispensing system applies small to large volumes of precision beads or metered shots of mixed resins.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88794</guid>
      <pubDate>Wed, 28 Sep 2011 15:03:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88794-sealant-equipment-engineering-servo-flo-704-meter-mix-dispense-system-improves-product-quality</link>
    </item>
    <item>
      <title>ATS Automation Tooling Systems-Supertrak: Revolution in High-Speed Pallet Transport</title>
      <description>
        <![CDATA[With the ATS Supertrak modular conveyor system, the direction, acceleration, speed and position of each individual pallet are completely programmable.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88826</guid>
      <pubDate>Wed, 28 Sep 2011 15:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88826-ats-automation-tooling-systems-supertrak-revolution-in-high-speed-pallet-transport</link>
    </item>
    <item>
      <title>Henkel Corp.-Loctite Structural Adhesives</title>
      <description>
        <![CDATA[Loctite structural adhesives are nearly two times stronger than spot welds and bolts.  ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88854</guid>
      <pubDate>Wed, 28 Sep 2011 14:53:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88854-henkel-corp-loctite-structural-adhesives</link>
    </item>
    <item>
      <title>Promess Inc.-Electromechanical Rotating Press</title>
      <description>
        <![CDATA[Promess has designed a complete line of electromechanical rotating press systems to provide a solution for the most demanding applications.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88784</guid>
      <pubDate>Wed, 28 Sep 2011 14:51:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88784-promess-inc-electromechanical-rotating-press</link>
    </item>
    <item>
      <title>Specialty Coating Systems-Precisioncoat Offers Accuracy and Flexibility</title>
      <description>
        <![CDATA[SCS is an industry-leader with its fully automated Precisioncoat selective spray and dispense system, featuring motorized tilt and rotate functionality, fiducial recognition, needle calibration and offline programming.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88796</guid>
      <pubDate>Wed, 28 Sep 2011 14:46:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88796-specialty-coating-systems-precisioncoat-offers-accuracy-and-flexibility</link>
    </item>
    <item>
      <title>KitPackers-Premixed and Frozen Packaging Lowers Costs</title>
      <description>
        <![CDATA[KitPackers specializes in packaging premixed multicomponent adhesives and sealants in easy to use single-component packaging dramatically simplifying your material application process.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88855</guid>
      <pubDate>Wed, 28 Sep 2011 14:44:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88855-kitpackers-premixed-and-frozen-packaging-lowers-costs</link>
    </item>
    <item>
      <title>Ellsworth Adhesives-Introducing the Ellsworth Packaging Advantage</title>
      <description>
        <![CDATA[Ellsworth Adhesives has developed innovative packaging systems to help protect materials packaged in containers susceptible to damage. 
      </description>
      <guid>http://www.assemblymag.com/articles/88852</guid>
      <pubDate>Wed, 28 Sep 2011 14:41:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88852-ellsworth-adhesives-introducing-the-ellsworth-packaging-advantage</link>
    </item>
    <item>
      <title>Microscan-Improve Efficiency And Reduce Defects With Simplified Machine Vision</title>
      <description>
        <![CDATA[With Microscan&#8217;s new Vision HAWK smart camera, both integrators and end-users have a scalable, fully integrated vision solution to confidently solve any inspection, verification, or auto ID application.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88857</guid>
      <pubDate>Wed, 28 Sep 2011 14:34:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88857-microscan-improve-efficiency-and-reduce-defects-with-simplified-machine-vision</link>
    </item>
    <item>
      <title>Creform Corp.-Cart ‘Harnesses' Wiring Components for Assembly, Transport</title>
      <description>
        <![CDATA[This Creform cart helps prevent tangling and misidentification of wiring and wire harnesses.       ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88841</guid>
      <pubDate>Wed, 28 Sep 2011 13:27:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88841-creform-corp-cart-harnesses-wiring-components-for-assembly-transport</link>
    </item>
    <item>
      <title>Techno Inc.-Multiaxis Stepper Controller</title>
      <description>
        <![CDATA[The iMC-P1 single- to four-axis controller can be used for assembly, pick-and-place, dispensing, testing, drilling, routing, welding and general automation applications.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88800</guid>
      <pubDate>Wed, 28 Sep 2011 13:24:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88800-techno-inc-multiaxis-stepper-controller</link>
    </item>
    <item>
      <title>Spirol International-Disc Spring Product Line</title>
      <description>
        <![CDATA[Spirol disc springs are conically shaped, washer-type components designed to be axially loaded.   ]]>
      </description>
      <guid>http://www.assemblymag.com/articles/88797</guid>
      <pubDate>Wed, 28 Sep 2011 13:22:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/88797-spirol-international-disc-spring-product-line</link>
    </item>
  </channel>
</rss>
