<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/" xmlns:content="http://purl.org/rss/1.0/modules/content/">
  <channel>
    <title>Assembly and Test Solutions</title>
    <description>PROMESS-sponsored resources for assembly and test, systems, applications, success stories, and engineering expertise.</description>
    <link>https://www.assemblymag.com/rss/6644</link>
    <language>en-us</language>
    <item>
      <title>Validate and Optimize Your Assembly Process with the Promess Process Development Center</title>
      <description>Reduce risk, improve quality, and accelerate production with real-world assembly process validation, testing, and engineering support at the Promess Process Development Center.</description>
      <content:encoded>
        <![CDATA[<p>Reduce risk, improve quality, and accelerate production with real-world assembly process validation, testing, and engineering support at the Promess Process Development Center.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/100184</guid>
      <pubDate>Mon, 29 Jun 2026 00:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/100184-validate-and-optimize-your-assembly-process-with-the-promess-process-development-center</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/2026/06/29/T3A1_June-2026.webp?t=1782744990" type="image/png" length="589226"/>
    </item>
    <item>
      <title>Promess REMAP: Precision Rotational and Linear Force in a Single Press</title>
      <description>Promess Applications Engineer Peter Parsons walks through how the REMAP works, what makes it different from other press-and-rotate solutions, and where it delivers the most value on the manufacturing floor.</description>
      <content:encoded>
        <![CDATA[<p>Promess Applications Engineer Peter Parsons walks through how the REMAP works, what makes it different from other press-and-rotate solutions, and where it delivers the most value on the manufacturing floor.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/100072</guid>
      <pubDate>Wed, 13 May 2026 16:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/100072-promess-remap-precision-rotational-and-linear-force-in-a-single-press</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/2026/05/13/T2-May-2026_REMAP-Image-900x550.webp?t=1778701824" type="image/jpeg" length="44045"/>
    </item>
    <item>
      <title>Precision Universal Joint Assembly Using Dual Electro-Mechanical Assembly Presses</title>
      <description>Learn how dual Promess Electro-Mechanical Assembly Presses improve universal joint assembly by maintaining precise spider alignment, reducing defects, and increasing production efficiency.</description>
      <content:encoded>
        <![CDATA[<p>Learn how dual Promess Electro-Mechanical Assembly Presses improve universal joint assembly by maintaining precise spider alignment, reducing defects, and increasing production efficiency.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99979</guid>
      <pubDate>Fri, 10 Apr 2026 10:15:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/99979-precision-universal-joint-assembly-using-dual-electro-mechanical-assembly-presses</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic4/T4A2_April-2026-Spider-Alignment.webp?t=1775830192" type="image/jpeg" length="27321"/>
    </item>
    <item>
      <title>Precision Crankshaft and Harmonic Balancer Assembly Without Thrust Bearing Damage</title>
      <description>Learn how a pull-based assembly process using the Promess REMAP eliminates internal loading, protects critical components, and improves long-term engine reliability.</description>
      <content:encoded>
        <![CDATA[<p>Learn how a pull-based assembly process using the Promess REMAP eliminates internal loading, protects critical components, and improves long-term engine reliability.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99978</guid>
      <pubDate>Fri, 10 Apr 2026 10:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/articles/99978-precision-crankshaft-and-harmonic-balancer-assembly-without-thrust-bearing-damage</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic4/T4A1_April-2026Crankshaft-and-Harmonic-Balancer-.webp?t=1775829754" type="image/png" length="129697"/>
    </item>
    <item>
      <title>Functional Assembly with EMAP: Pressing and Calibrating a Pressure Relief Valve</title>
      <description>See how Promess uses force, motion, and sensor feedback to assemble a pressure relief valve to its functional opening pressure.</description>
      <content:encoded>
        <![CDATA[<p>See how Promess uses force, motion, and sensor feedback to assemble a pressure relief valve to its functional opening pressure.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99920</guid>
      <pubDate>Mon, 16 Mar 2026 11:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99920-functional-assembly-with-emap-pressing-and-calibrating-a-pressure-relief-valve</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/T3A3-March-2026.webp?t=1773672538" type="image/jpeg" length="93476"/>
    </item>
    <item>
      <title>Electric Press Software Basics: Getting Started with Promess Software</title>
      <description>Learn how to build a simple, reliable EMAP program using UltraPRO software. Senior Applications Engineer John Derry walks through the core functions you need to begin programming with confidence.</description>
      <content:encoded>
        <![CDATA[<p>Learn how to build a simple, reliable EMAP program using UltraPRO software. Senior Applications Engineer John Derry walks through the core functions you need to begin programming with confidence.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99919</guid>
      <pubDate>Mon, 16 Mar 2026 10:45:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99919-electric-press-software-basics-getting-started-with-promess-software</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/T3A2-March-2026.webp?t=1773672538" type="image/jpeg" length="69241"/>
    </item>
    <item>
      <title>Go from Programming to Production in Under an Hour</title>
      <description>Learn how to set up a press to force application quickly and confidently. In this on-demand training, Promess engineers show you how to program, validate, and begin production in less than an hour.</description>
      <content:encoded>
        <![CDATA[<p>Learn how to set up a press to force application quickly and confidently. In this on-demand training, Promess engineers show you how to program, validate, and begin production in less than an hour.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99918</guid>
      <pubDate>Mon, 16 Mar 2026 10:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99918-go-from-programming-to-production-in-under-an-hour</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/T3A1_revised.webp?t=1773672538" type="image/jpeg" length="64758"/>
    </item>
    <item>
      <title>Combining Linear and Rotational Precision in One System</title>
      <description>Assembly processes are becoming more complex, and manufacturers need solutions that combine multiple motions without sacrificing accuracy. The Promess REMAP delivers programmable linear and rotational control in a single compact, ready to run unit.</description>
      <content:encoded>
        <![CDATA[<p>Assembly processes are becoming more complex, and manufacturers need solutions that combine multiple motions without sacrificing accuracy. The Promess REMAP delivers programmable linear and rotational control in a single compact, ready to run unit.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99821</guid>
      <pubDate>Wed, 04 Feb 2026 16:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99821-combining-linear-and-rotational-precision-in-one-system</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic2/T2A2_Feb-2026_REMAP.webp?t=1770239481" type="image/jpeg" length="52525"/>
    </item>
    <item>
      <title>Precision Assembly and Testing with Electric Torque Control</title>
      <description>Modern manufacturing demands torque accuracy, traceability, and repeatability. The Promess TorquePRO delivers all three with a fully electric, programmable system designed for precision assembly and test applications across every industry.</description>
      <content:encoded>
        <![CDATA[<p>Modern manufacturing demands torque accuracy, traceability, and repeatability. The Promess TorquePRO delivers all three with a fully electric, programmable system designed for precision assembly and test applications across every industry.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99820</guid>
      <link>https://www.assemblymag.com/articles/99820-precision-assembly-and-testing-with-electric-torque-control</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic2/T2A1_Feb-2026_TorquePRO.webp?t=1770238888" type="image/jpeg" length="50415"/>
    </item>
    <item>
      <title>Accurate Bearing Drag Force Testing with REMAP and Torque Table</title>
      <description>This video demonstrates how Promess measures drag force in ball and roller bearings using a REMAP servo press and Torque Table.</description>
      <content:encoded>
        <![CDATA[<p>This video demonstrates how Promess measures drag force in ball and roller bearings using a REMAP servo press and Torque Table.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99772</guid>
      <pubDate>Wed, 14 Jan 2026 14:45:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99772-accurate-bearing-drag-force-testing-with-remap-and-torque-table</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic4/T4_New-Jan-2026-Bearing-Drag-Force.webp?t=1768422469" type="image/jpeg" length="81994"/>
    </item>
    <item>
      <title>How Intelligent Press Programming Eliminated Scrap and Solved Transmission Sealing Failures</title>
      <description>Learn how a simple plug change and intelligent EMAP programming eliminated cracked housings, reduced scrap, and enabled over 35 million leak-free installations for a major transmission manufacturer.</description>
      <content:encoded>
        <![CDATA[<p>Learn how a simple plug change and intelligent EMAP programming eliminated cracked housings, reduced scrap, and enabled over 35 million leak-free installations for a major transmission manufacturer.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99771</guid>
      <pubDate>Wed, 14 Jan 2026 14:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99771-how-intelligent-press-programming-eliminated-scrap-and-solved-transmission-sealing-failures</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/T1_New-Jan-2026-Beta-Plug.webp?t=1768418729" type="image/jpeg" length="57144"/>
    </item>
    <item>
      <title>Ensuring Precision Trigger Performance for Military Handguns with Promess EMAP Technology</title>
      <description>Learn how a U.S. military handgun manufacturer achieved extremely tight trigger-force tolerances, full traceability, and consistent weapon performance using a Promess EMAP equipped with a high-precision 10 lb load cell.</description>
      <content:encoded>
        <![CDATA[<p>Learn how a U.S. military handgun manufacturer achieved extremely tight trigger-force tolerances, full traceability, and consistent weapon performance using a Promess EMAP equipped with a high-precision 10 lb load cell.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99711</guid>
      <pubDate>Mon, 15 Dec 2025 17:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99711-ensuring-precision-trigger-performance-for-military-handguns-with-promess-emap-technology</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic4/Topic4_Article2.webp?t=1765834781" type="image/jpeg" length="64253"/>
    </item>
    <item>
      <title>Automating Rifle Barrel Assembly with Precision: How Promess TorquePRO Improved Alignment, Accuracy, and Traceability</title>
      <description>Discover how a firearms manufacturer eliminated manual alignment, reduced torque variability, and achieved full process traceability.</description>
      <content:encoded>
        <![CDATA[<p>Discover how a firearms manufacturer eliminated manual alignment, reduced torque variability, and achieved full process traceability.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99710</guid>
      <pubDate>Mon, 15 Dec 2025 16:30:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99710-automating-rifle-barrel-assembly-with-precision-how-promess-torquepro-improved-alignment-accuracy-and-traceability</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic4/Topic4_Article1.webp?t=1765834781" type="image/jpeg" length="45286"/>
    </item>
    <item>
      <title>Inside a Promess Training Session</title>
      <description>See how Promess delivers real-world training through hands-on instruction and live demonstrations.</description>
      <content:encoded>
        <![CDATA[<p>See how Promess delivers real-world training through hands-on instruction and live demonstrations.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99708</guid>
      <pubDate>Fri, 12 Dec 2025 15:15:00 -0500</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99708-inside-a-promess-training-session</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/Topic3_Article3.webp?t=1765568998" type="image/jpeg" length="67120"/>
    </item>
    <item>
      <title>Test Your Process at the Promess Process Development Center</title>
      <description>Visit the Promess Process Development Center to test and refine your manufacturing process with our expert engineering team.</description>
      <content:encoded>
        <![CDATA[<p>Visit the Promess Process Development Center to test and refine your manufacturing process with our expert engineering team.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99707</guid>
      <pubDate>Fri, 12 Dec 2025 15:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99707-test-your-process-at-the-promess-process-development-center</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/Topic3_Article2.webp?t=1766475488" type="image/jpeg" length="86958"/>
    </item>
    <item>
      <title>Inside a Promess Engineered Solution: High-Speed Pressing with EMAP + Servo Tool Changer</title>
      <description>Experience Promess’ newest engineered solution, designed for progressive builds and high mix, low volume manufacturing.</description>
      <content:encoded>
        <![CDATA[<p>Experience Promess’ newest engineered solution, designed for progressive builds and high mix, low volume manufacturing.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99706</guid>
      <pubDate>Fri, 12 Dec 2025 14:45:00 -0500</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99706-inside-a-promess-engineered-solution-high-speed-pressing-with-emap-servo-tool-changer</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/Topic3_Article1.webp?t=1765568998" type="image/jpeg" length="90620"/>
    </item>
    <item>
      <title>Precision in Hazardous Locations: Introducing the Promess H-Series Servo Press</title>
      <description>Discover how the Promess H-Series brings safe, programmable force control and real-time process intelligence to hazardous and explosive manufacturing environments.</description>
      <content:encoded>
        <![CDATA[<p>Discover how the Promess H-Series brings safe, programmable force control and real-time process intelligence to hazardous and explosive manufacturing environments.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99703</guid>
      <pubDate>Thu, 11 Dec 2025 15:45:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99703-precision-in-hazardous-locations-introducing-the-promess-h-series-servo-press</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic2/Topic2_Article3.webp?t=1765484263" type="image/jpeg" length="45288"/>
    </item>
    <item>
      <title>Flexible, Intelligent, and Ready to Work: The Power of Promess Work Stations</title>
      <description>Learn how Promess Work Stations deliver turnkey precision, flexibility, and data-driven performance for assembly and test operations of any size.</description>
      <content:encoded>
        <![CDATA[<p>Learn how Promess Work Stations deliver turnkey precision, flexibility, and data-driven performance for assembly and test operations of any size.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99702</guid>
      <pubDate>Thu, 11 Dec 2025 15:30:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99702-flexible-intelligent-and-ready-to-work-the-power-of-promess-work-stations</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic2/Topic2_Article2.webp?t=1765484264" type="image/jpeg" length="68918"/>
    </item>
    <item>
      <title>Precision That Transforms Assembly: Why Manufacturers Choose the Promess EMAP</title>
      <description>Discover how the Promess EMAP delivers unmatched precision, adaptive force control, and complete traceability for today’s most demanding assembly and test applications.</description>
      <content:encoded>
        <![CDATA[<p>Discover how the Promess EMAP delivers unmatched precision, adaptive force control, and complete traceability for today’s most demanding assembly and test applications.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99701</guid>
      <pubDate>Thu, 11 Dec 2025 15:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99701-precision-that-transforms-assembly-why-manufacturers-choose-the-promess-emap</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic2/Topic2_Article1.webp?t=1765484264" type="image/jpeg" length="48595"/>
    </item>
    <item>
      <title>How One Pump Manufacturer Saved $1 Million by Replacing a Hydraulic Press with a Promess EMAP</title>
      <description>See how one pump manufacturer eliminated premature failures and saved $1 million in warranty costs by switching from a hydraulic press to the Promess EMAP.</description>
      <content:encoded>
        <![CDATA[<p>See how one pump manufacturer eliminated premature failures and saved $1 million in warranty costs by switching from a hydraulic press to the Promess EMAP.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99699</guid>
      <pubDate>Wed, 10 Dec 2025 14:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99699-how-one-pump-manufacturer-saved-1-million-by-replacing-a-hydraulic-press-with-a-promess-emap</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/Topic1_Article3.webp?t=1765388632" type="image/jpeg" length="53726"/>
    </item>
    <item>
      <title>How a Heavy Truck Manufacturer Streamlined Turbocharger Assembly with a Multi-Axis Press Solution</title>
      <description>See how a heavy truck manufacturer eliminated manual repositioning and improved turbocharger assembly precision using a fully programmable multi-axis press solution from Promess.</description>
      <content:encoded>
        <![CDATA[<p>See how a heavy truck manufacturer eliminated manual repositioning and improved turbocharger assembly precision using a fully programmable multi-axis press solution from Promess.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99698</guid>
      <pubDate>Wed, 10 Dec 2025 13:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99698-how-a-heavy-truck-manufacturer-streamlined-turbocharger-assembly-with-a-multi-axis-press-solution</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/Topic1_Article2.webp?t=1765388632" type="image/jpeg" length="74135"/>
    </item>
    <item>
      <title>How One Electronics Manufacturer Reduced Scrap &amp; Increased Reliability with Press-Fit Assembly</title>
      <description>Discover how a leading electronics manufacturer slashed scrap rates, improved reliability, and eliminated hand-soldering bottlenecks by switching to compliant pin press-fit assembly powered by Promess’ EMAP technology.</description>
      <content:encoded>
        <![CDATA[<p>Discover how a leading electronics manufacturer slashed scrap rates, improved reliability, and eliminated hand-soldering bottlenecks by switching to compliant pin press-fit assembly powered by Promess’ EMAP technology.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99697</guid>
      <pubDate>Wed, 10 Dec 2025 12:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99697-how-one-electronics-manufacturer-reduced-scrap-and-increased-reliability-with-press-fit-assembly</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/Topic1_Article1.webp?t=1765388632" type="image/jpeg" length="50348"/>
    </item>
  </channel>
</rss>
