<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/" xmlns:content="http://purl.org/rss/1.0/modules/content/">
  <channel>
    <title>Manufacturing Success Stories</title>
    <description>Explore real-world case studies, application stories, testimonials, and industry examples that prove performance.</description>
    <link>https://www.assemblymag.com/rss/6645</link>
    <language>en-us</language>
    <item>
      <title>How Intelligent Press Programming Eliminated Scrap and Solved Transmission Sealing Failures</title>
      <description>Learn how a simple plug change and intelligent EMAP programming eliminated cracked housings, reduced scrap, and enabled over 35 million leak-free installations for a major transmission manufacturer.</description>
      <content:encoded>
        <![CDATA[<p>Learn how a simple plug change and intelligent EMAP programming eliminated cracked housings, reduced scrap, and enabled over 35 million leak-free installations for a major transmission manufacturer.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99771</guid>
      <pubDate>Wed, 14 Jan 2026 14:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99771-how-intelligent-press-programming-eliminated-scrap-and-solved-transmission-sealing-failures</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/T1_New-Jan-2026-Beta-Plug.webp?t=1768418729" type="image/jpeg" length="57144"/>
    </item>
    <item>
      <title>How One Pump Manufacturer Saved $1 Million by Replacing a Hydraulic Press with a Promess EMAP</title>
      <description>See how one pump manufacturer eliminated premature failures and saved $1 million in warranty costs by switching from a hydraulic press to the Promess EMAP.</description>
      <content:encoded>
        <![CDATA[<p>See how one pump manufacturer eliminated premature failures and saved $1 million in warranty costs by switching from a hydraulic press to the Promess EMAP.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99699</guid>
      <pubDate>Wed, 10 Dec 2025 14:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99699-how-one-pump-manufacturer-saved-1-million-by-replacing-a-hydraulic-press-with-a-promess-emap</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/Topic1_Article3.webp?t=1765388632" type="image/jpeg" length="53726"/>
    </item>
    <item>
      <title>How a Heavy Truck Manufacturer Streamlined Turbocharger Assembly with a Multi-Axis Press Solution</title>
      <description>See how a heavy truck manufacturer eliminated manual repositioning and improved turbocharger assembly precision using a fully programmable multi-axis press solution from Promess.</description>
      <content:encoded>
        <![CDATA[<p>See how a heavy truck manufacturer eliminated manual repositioning and improved turbocharger assembly precision using a fully programmable multi-axis press solution from Promess.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99698</guid>
      <pubDate>Wed, 10 Dec 2025 13:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99698-how-a-heavy-truck-manufacturer-streamlined-turbocharger-assembly-with-a-multi-axis-press-solution</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/Topic1_Article2.webp?t=1765388632" type="image/jpeg" length="74135"/>
    </item>
    <item>
      <title>How One Electronics Manufacturer Reduced Scrap &amp; Increased Reliability with Press-Fit Assembly</title>
      <description>Discover how a leading electronics manufacturer slashed scrap rates, improved reliability, and eliminated hand-soldering bottlenecks by switching to compliant pin press-fit assembly powered by Promess’ EMAP technology.</description>
      <content:encoded>
        <![CDATA[<p>Discover how a leading electronics manufacturer slashed scrap rates, improved reliability, and eliminated hand-soldering bottlenecks by switching to compliant pin press-fit assembly powered by Promess’ EMAP technology.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/articles/99697</guid>
      <pubDate>Wed, 10 Dec 2025 12:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/articles/99697-how-one-electronics-manufacturer-reduced-scrap-and-increased-reliability-with-press-fit-assembly</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic1/Topic1_Article1.webp?t=1765388632" type="image/jpeg" length="50348"/>
    </item>
  </channel>
</rss>
