<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/" xmlns:content="http://purl.org/rss/1.0/modules/content/">
  <channel>
    <title>Engineering Expertise &amp; Resources</title>
    <description>Get engineering insights and resources, technical guides, white papers, process development help, training, webinars.</description>
    <link>https://www.assemblymag.com/rss/6647</link>
    <language>en-us</language>
    <item>
      <title>Validate and Optimize Your Assembly Process with the Promess Process Development Center</title>
      <description>Reduce risk, improve quality, and accelerate production with real-world assembly process validation, testing, and engineering support at the Promess Process Development Center.</description>
      <content:encoded>
        <![CDATA[<p>Reduce risk, improve quality, and accelerate production with real-world assembly process validation, testing, and engineering support at the Promess Process Development Center.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/100184</guid>
      <pubDate>Mon, 29 Jun 2026 00:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/100184-validate-and-optimize-your-assembly-process-with-the-promess-process-development-center</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/2026/06/29/T3A1_June-2026.webp?t=1782744990" type="image/png" length="589226"/>
    </item>
    <item>
      <title>Functional Assembly with EMAP: Pressing and Calibrating a Pressure Relief Valve</title>
      <description>See how Promess uses force, motion, and sensor feedback to assemble a pressure relief valve to its functional opening pressure.</description>
      <content:encoded>
        <![CDATA[<p>See how Promess uses force, motion, and sensor feedback to assemble a pressure relief valve to its functional opening pressure.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99920</guid>
      <pubDate>Mon, 16 Mar 2026 11:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99920-functional-assembly-with-emap-pressing-and-calibrating-a-pressure-relief-valve</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/T3A3-March-2026.webp?t=1773672538" type="image/jpeg" length="93476"/>
    </item>
    <item>
      <title>Electric Press Software Basics: Getting Started with Promess Software</title>
      <description>Learn how to build a simple, reliable EMAP program using UltraPRO software. Senior Applications Engineer John Derry walks through the core functions you need to begin programming with confidence.</description>
      <content:encoded>
        <![CDATA[<p>Learn how to build a simple, reliable EMAP program using UltraPRO software. Senior Applications Engineer John Derry walks through the core functions you need to begin programming with confidence.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99919</guid>
      <pubDate>Mon, 16 Mar 2026 10:45:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99919-electric-press-software-basics-getting-started-with-promess-software</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/T3A2-March-2026.webp?t=1773672538" type="image/jpeg" length="69241"/>
    </item>
    <item>
      <title>Go from Programming to Production in Under an Hour</title>
      <description>Learn how to set up a press to force application quickly and confidently. In this on-demand training, Promess engineers show you how to program, validate, and begin production in less than an hour.</description>
      <content:encoded>
        <![CDATA[<p>Learn how to set up a press to force application quickly and confidently. In this on-demand training, Promess engineers show you how to program, validate, and begin production in less than an hour.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99918</guid>
      <pubDate>Mon, 16 Mar 2026 10:00:00 -0400</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99918-go-from-programming-to-production-in-under-an-hour</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/T3A1_revised.webp?t=1773672538" type="image/jpeg" length="64758"/>
    </item>
    <item>
      <title>Inside a Promess Training Session</title>
      <description>See how Promess delivers real-world training through hands-on instruction and live demonstrations.</description>
      <content:encoded>
        <![CDATA[<p>See how Promess delivers real-world training through hands-on instruction and live demonstrations.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99708</guid>
      <pubDate>Fri, 12 Dec 2025 15:15:00 -0500</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99708-inside-a-promess-training-session</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/Topic3_Article3.webp?t=1765568998" type="image/jpeg" length="67120"/>
    </item>
    <item>
      <title>Test Your Process at the Promess Process Development Center</title>
      <description>Visit the Promess Process Development Center to test and refine your manufacturing process with our expert engineering team.</description>
      <content:encoded>
        <![CDATA[<p>Visit the Promess Process Development Center to test and refine your manufacturing process with our expert engineering team.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99707</guid>
      <pubDate>Fri, 12 Dec 2025 15:00:00 -0500</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99707-test-your-process-at-the-promess-process-development-center</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/Topic3_Article2.webp?t=1766475488" type="image/jpeg" length="86958"/>
    </item>
    <item>
      <title>Inside a Promess Engineered Solution: High-Speed Pressing with EMAP + Servo Tool Changer</title>
      <description>Experience Promess’ newest engineered solution, designed for progressive builds and high mix, low volume manufacturing.</description>
      <content:encoded>
        <![CDATA[<p>Experience Promess’ newest engineered solution, designed for progressive builds and high mix, low volume manufacturing.</p>]]>
      </content:encoded>
      <guid>http://www.assemblymag.com/blogs/26/post/99706</guid>
      <pubDate>Fri, 12 Dec 2025 14:45:00 -0500</pubDate>
      <link>https://www.assemblymag.com/blogs/26-engineering-expertise-resources/post/99706-inside-a-promess-engineered-solution-high-speed-pressing-with-emap-servo-tool-changer</link>
      <enclosure url="https://www.assemblymag.com/ext/resources/InfoCenter/Promess/topic3/Topic3_Article1.webp?t=1765568998" type="image/jpeg" length="90620"/>
    </item>
  </channel>
</rss>
