Automated Assembly SystemsMotion Control
High-Performance Servos Boost Throughput
January 6, 2012
highPerform_bodyFifty milliseconds may not seem like a lot of time. Indeed, the human eye takes between 300 and 400 milliseconds to complete a single blink. And yet in the context of a high-speed automated assembly system, in which a single linear actuator might make more than a dozen moves per minute, 50 milliseconds here and there can really add up.
Consider a simple two-axis servo-driven motion system that produces one part with each cycle. Let’s say the X axis requires 0.5 second to move to one position and 0.5 second to move back, with 50 milliseconds of settling time at each position. Similarly, the Z axis requires 0.2 second to move to one position and 0.2 second to move back, with the same 50 milliseconds of settling time at each position. All totaled, then, the system takes 1.6 seconds to complete a cycle, including 200 milliseconds of settling time.
That equates to 37.5 parts per minute. At a price per part of $0.10, the system therefore generates $225 in revenue per hour.
But what if you could shave a few milliseconds off settling time with a higher performance servo system? Instead of 50 milliseconds of settling time at each position, the system requires just 4 milliseconds.
Now, the system takes 1.416 seconds to complete a cycle, including 16 milliseconds of settling time. That equates to 42.37 parts per minute, enabling the system to generate $254.24 in revenue per hour, or $29.24 more per hour than the original system. In a two-shift operation running six days a week, that adds up to an additional $140,353 in revenue.
“If you have an application that makes one move, and 30 minutes goes by before it makes another move, a high-performance servo system isn’t going to do you much good,” says Scott Carlberg, product marketing manager for the Drives and Motion Div. of Yaskawa America Inc. “But, in an assembly operation with three axes moving 25 times per minute for hours, a high-performance servo system is going to have a big effect.”
In a servo-driven motion control system, settling time is the difference between when the system is supposed to be at a commanded position and when it actually arrives there. Various factors can affect settling time, including system bandwidth, feedback resolution, load inertia, move profile, machine resonances and other mechanical limitations.
“Settling time for an average servo system in today’s market ranges from 50 to 100 milliseconds,” says Carlberg. “Settling time for a high-performance servo system, such as Yaskawa’s Sigma-5, can consistently get down in the 5 to 10 millisecond range.”
One feature that differentiates a high-performance servo system from a standard one is greater bandwidth in the current and velocity control loops. The velocity control loop on the Sigma-5 has a bandwidth of 1.6 kilohertz. In comparison, the velocity control loop on the S200 servo drive from Kollmorgen, for example, has a bandwidth of 800 hertz.
With more bandwidth, the amplifier can receive and process more data from the servomotor. For example, a 20-bit abso-lute encoder supplies more than 1 million pulses per revolution. “That extra feedback allows you to crank up the servo gain, which allows the system to reach the commanded position faster,” says Carlberg.
High bandwidth also enables the drive to perform more complex control algorithms. For example, the Sigma-5 drive has algorithms for automatic system tuning and vibration suppression.
KEYWORDS: high-speed assembly servo system
  • Servos Revolutionize High-Speed Assembly
    Boeing Debuts High-Throughput Small Satellite Production Line
  • High-Tech Conversions
