Lasko Metal Products Inc. (West Chester, PA), a manufacturer of ventilation devices and household appliances, needed a welding method for the assembly of reservoir jugs for its humidifiers. These oddly-shaped reservoir jugs are large and can hold several gallons of fluid.
Compared with die-cut or molded solid gaskets, liquid gaskets have many design advantages. This article reviews the applications for these materials and tells how best to dispense them.
The Marshalltown, IA, plant of Lennox Industries, a manufacturer of residential and commercial heating and air conditioning equipment, required automation for a new portion of their gas furnace manufacturing process.
BG Laboratories Inc. (Binghampton, NY) manufactures space-saving miniature transformers for laptop computer modems, and the thin-wall molding capabilities and other properties of DuPont's (Wilmington, DE) Zenite LCP 7130 play a key role in the manufacturing process. Zenite LCP 7130 is a 30 percent glass-reinforced resin with a heat-deflection temperature of 552 F and UL94 V-O flammability rating.
Among manufacturers of electronic products, few have been as vertically integrated as Fluke Corp. Arial change; Fluke now outsources many aspects of production. To get some insight into how electronics manufacturers make “build-or-buy” decisions, we spoke with David Gunderson, a project manager with Fluke Networks.
The U.S. Air Force wanted an adhesive for temporarily attaching small test packages to the exterior of a jet without fasteners. EIC Laboratories Inc. came up with a solution: a high-strength adhesive that disbonds from a metal surface when an electrical current passes through it.
Rayovac Corp. (Madison, WI) carefully selects the materials that make up its industrial flashlights, because industrial and construction workers purchase flashlights based on their ability to withstand harsh conditions.
How you measure torque can affect your perception of how well your fastening tools perform. This article reviews methods for measuring the torque produced by a tool before, during and after fastening.
