Assembly and test solutions logo
  • Home
  • Success Stories
  • Precision Systems
  • Engineering Resources
  • Industries, Applications
  • Brochures
  • ASM Home
Assembly and Test SolutionsPrecision Assembly & Test Systems
Precision in Hazardous Locations: Introducing the Promess H-Series Servo Press
Promess H-Series servo press
Image Credit: Promess Inc.
December 11, 2025
Bringing Safe, Programmable Press Technology to Explosive and High-Risk Environments
Hazardous manufacturing environments such as those found in aerospace, defense, munitions, and chemical processing require equipment that delivers precision without compromising safety. Traditional technologies often fall short, creating barriers for companies that need intelligent force control and complete traceability in demanding conditions.
content provided by promessThe Promess H-Series solves this problem by bringing the capabilities of the EMAP servo press into a Class I, Division 2–rated system, built to perform safely where flammable gases or vapors may be present.
What Makes the H-Series Essential for Hazardous Applications
Hazardous-Location Certified
Designed specifically for environments that require explosion-proof or ignition-protected equipment.
Programmable Motion and Force Control
The H-Series offers the same precision as a standard EMAP, programmable force and position, high-resolution monitoring, and real-time feedback.
Rugged, Reliable Construction
Engineered with sealed housings, reinforced components, and protective architecture to withstand extreme conditions.
Data Capture for Every Cycle
Even in hazardous environments, manufacturers can record force-distance signatures, traceability data, and quality metrics for every assembly.
Adaptable to Mission-Critical Applications
Ideal for assembling energetic devices, defense components, aerospace actuators, ignitors, and sealed systems.
Where the H-Series Makes an Impact
  • Munitions assembly
  • Aerospace component joining
  • Energetic device production
  • Hazardous chemical environments
  • Oil, gas, and military applications
When safety and precision must coexist, the H-Series provides a reliable, compliant, and intelligent solution built for the highest-stakes environments.
Learn more about our H-Series Systems
KEYWORDS: servo press
Promess
Promess updates, follow on LinkedIn
LinkedIn
