ColumnsLean Manufacturing Assembly
Leading Lean: Driving Innovation at Every Level
By Jamie Flinchbaugh
November 22, 2010
Every corporation wants to be innovative. But, being innovative is not a behavior. It’s not something on your to-do list between picking up dry cleaning and writing performance reviews. Innovation is the by-product of plans, processes, people and behaviors.
Innovation is a major attribute in the competitiveness of a company. There are many ways to achieve innovation, and no one thing will be enough. There is no question that sometimes one very smart person can lead to great innovations. However, this isn’t very replicable or sustainable.
What does lean have to do with innovation? When done well, lean leads to innovation at all levels of the organization. It may not lead to game-changing innovations like the Post-It note or the iPod, but it cer-tainly will produce innovations that improve products, delight customers, and strengthen performance. Lean is not all about waste elimination, despite many common definitions that say so.
We often assume that most innovations come from teams that are dedicated to it. Perhaps specific, fo-cused innovations do come from such teams, but not the bulk of innovations that make a difference in sustainably competitive organizations. You never know where the next innovation might come from. The more broadly distributed innovative activities are, the more likely you will see big wins. The more balls you put into play, the more likely you will see home runs. Many innovation books tell you to put all your innovation into one team. This is, of course, easy to manage. But, to increase your chances for success, put innovation into every person.
Three lean behaviors drive innovation: customer focus, problem solving and learning.
Innovation begins with filling the needs of people, either current or future customers. When lean com-panies focus on providing value, they get curious about the met and unmet needs of customers. This fo-cus drives these organizations to make their customers’ problems their own and to see value where oth-ers don’t.
Problem solving is a core capability, because it drives us to engage problems that others might ignore. It drives us to dig deeper. This deeper exploration leads to new insights into problems. Problem solving starts with good, focused problem statements. When we take the problem statement for granted, we might miss a wide range of opportunities.
Learning is about experimentation. It is the constant connection between cause and effect. Thomas Edi-son said, “I have not failed. I have merely found a thousand ways that won’t work.” Each experiment was an investment in his knowledge. Learning leads to innovation and invention.
When we put these three behaviors together-customer focus, problem solving and learning through ex-perimentation-innovation is the outcome.
It is important to build these behaviors, and the risks that come along with innovation, into the organiza-tion. This requires encouragement and recognition. If people are afraid to experiment because they get punished if their experiment fails, experimentation and the learning that goes with it will stop. Gordon Moore, co-founder of Intel, said, “Failures are not something to be avoided. You want to have them happen as quickly as you can, so you can make progress quickly.”
It’s also important to encourage the behaviors that go with innovation, and not just the outcomes. If you only recognize big outcomes, then people will only make the effort when they are likely to achieve a big outcome. If we encourage the right behaviors, we will see more of those behaviors, which in turn leads to the outcomes we desire.
Innovation is possible in any organization. You don’t need a specialized department. You don’t need a corporate initiative. Innovation can begin anywhere, even with yourself. Lean begins with you.
Blog Topics
Austin Weber
Assembly Automation
Ergo Corner
Hoffmann on Testing
Jim Camillo
Jim Smith
John Sprovieri
Recent Comments
Helpful for Trainees
Cable Assembly Manufacturers
Huawei for manufacturing?
should have a scanner and then 3D print the repair
IPC-A-610 and IPC-j-std-001
August 14, 2025
