Sponsored By
Dymax
TechnologiesAdhesives & Dispensing Assembly
Dymax logo
Dymax
Dymax manufactures light-curable adhesives and curing equipment for electronics, medical, and industrial applications, helping engineers improve process efficiency, reliability, and precision through optimized light-curing solutions.
By Jason Tomei
UV curing system
Image courtesy of Dymax
May 1, 2026
When selecting LED UV curing equipment, engineers often rely on data sheets to compare performance. Peak intensity is typically one of the most prominent specifications and can heavily influence decision-making.
However, peak intensity alone does not fully represent how a curing system will perform in a real manufacturing process.
At the core of UV curing is total energy delivered to the substrate, commonly referred to as dose, defined as the product of intensity and exposure time (Total Dose = Intensity x Time). While this relationship is well understood, the way intensity is measured and applied can vary significantly, introducing gaps between expected and actual performance.
Why Measurement Conditions Matter
One of the most overlooked variables in LED UV curing is working distance, the space between the emitter and the part being cured.
Manufacturers report intensity values using different measurement methods. Some report values taken directly at the emitter surface, while others measure at a defined distance where the light is focused. Without understanding these conditions, comparisons between systems can be misleading.
Because LED emitters are composed of many individual LEDs, the optical design, including lens shape, diode spacing, and thermal loading, directly influences how light converges or diverges as distance increases. Small variations in optic design can produce large differences in usable irradiance at working distances above 10–20 mm.
Two emitters with identical peak intensity can exhibit completely different intensity decay curves, making it essential to understand how each system behaves across the full range of intended working distances.
As distance increases, intensity naturally decreases due to light divergence. But the rate of that decrease depends heavily on emitter design. Some systems are optimized for close-range curing, delivering high intensity near the surface but dropping off quickly. Others are designed to maintain more consistent output across a wider range of distances.
While these differences are often not visible in standard specifications, measured performance over distance can reveal significant variation between systems that appear similar on paper.
In many cases, intensity can decrease rapidly as distance increases, particularly for emitters not designed with a defined focal point.
Figure 1. Intensity vs. Working Distance
Intensity vs. Working Distance Chart
Matching Equipment to the Application
Application requirements play a critical role in determining which emitter characteristics are most important.
In high-speed processes such as printing, substrates are typically positioned very close to the emitter. In these cases, maximizing intensity at the surface is often the primary objective, and systems designed for short working distances perform well.
However, many industrial applications involve more complex geometries. Printed circuit boards, for example, may include components of varying heights, while molded or dental parts often have irregular surfaces. In these situations, working distance is not constant across the part.
In applications with tall components, such as electrolytic capacitors, tall connectors, or multi‑layer subassemblies, the delivered energy can vary by orders of magnitude across just a few millimeters of height change. This can lead to under‑cured regions unless the emitter is engineered to maintain intensity across that depth.
For adhesive applications requiring deep or through‑gap curing, the ability of an emitter to retain intensity at mid‑range distances is often more important than its peak intensity at the glass. This is especially true for materials with higher optical densities or where the bond line is partially obstructed by surrounding features.
A system that performs well at close range may not deliver sufficient energy to areas further from the emitter. Conversely, a system designed for a defined focal distance may provide more consistent curing across varying geometries, even if its peak intensity appears lower in comparison.
In some assemblies, variations in component height can create working distance differences of several millimeters or more across a single part.
Looking Beyond a Single Number
Another important consideration is uniformity across the curing area. Data sheets typically report a single intensity value, usually measured at the center of the emission field. In practice, intensity is not evenly distributed.
Some emitters provide a relatively uniform intensity profile, while others exhibit a strong central peak with reduced intensity toward the edges.
Uniformity becomes increasingly critical in multi-cavity tooling, panelized assemblies, or large substrates, where edge‑drop can result in uneven cure progression and inconsistent mechanical properties across the part.
An emitter with a strong central peak may deliver more than double the intensity at the center compared to its edges, effectively changing the required exposure time depending on where the part is positioned under the array.
As working distance increases, these variations can become more pronounced, affecting overall cure consistency.
Components positioned away from the center of the emitter may receive a lower dose, which can require longer exposure times or lead to inconsistent results if not properly accounted for.
For example, two emitters with similar power output may deliver significantly different intensity at 25 mm or greater working distances, depending on how the light is focused.
From Specification to Real-World Performance
While data sheets are a useful starting point, they do not capture the full complexity of a curing process. Factors such as part geometry, working distance variation, emitter optics, and uniformity all influence how much energy is actually delivered to the substrate.
Because of this, evaluating curing systems under real operating conditions is essential.
Engineers should also consider how thermal management, diode aging, and drive current stability affect long-term irradiance output. Small decreases in optical efficiency over time have a compounded effect at longer working distances, where intensity is already reduced.
Radiometric measurements taken at the exact geometry of use—matching the part’s height variations and physical orientation—provide the most reliable indicator of true process capability.
Measuring performance at relevant distances and validating results with actual parts can help ensure the process is both efficient and repeatable.
A more complete understanding of how intensity behaves over distance allows engineers to better predict curing outcomes and design processes that are both robust and reliable.
Explore the Full Analysis
While data sheets provide a useful starting point, they often do not capture how LED emitters behave across real working distances and complex part geometries.
The full white paper expands on these concepts with measured intensity-over-distance comparisons, emitter design considerations, and practical guidance for evaluating curing performance in production environments.
Access the white paper “Comparison of Working Distance on Measured Intensity for LED Emitters” here.
KEYWORDS: adhesive bonding adhesive technology bonding light-curing adhesive UV cure adhesives
Jason Tomei is a Global Product Manager for Equipment at Dymax, where he focuses on the development and application of light-curing systems. He works with manufacturers across industries to optimize curing processes and improve production efficiency.
