MIRABEL, Quebec—Airbus is working to repurpose part of an aircraft assembly plant here that has been vacant since Bombardier ended production of the CRJ passenger jet.
Last month, NASA's Mars Perseverance rover landed on the red planet after 5.5 months of traveling through space. The rover's primary mission is to search for signs of ancient microscopic life and collect the first ever Martian soil samples for analysis.
After a nearly 20-year hiatus, supersonic passenger travel is about to make a comeback. One of the companies leading the charge is Boom Supersonic Inc.
Self-pierce riveting (SPR) is a cold joining process for fastening two or more sheets of material by driving a rivet through the top sheets and upsetting it, under the influence of a die, into the bottom sheet without breaking through it.
Many types of welding are used in manufacturing. Some, like gas metal arc, laser and ultrasonic, are quite well-known, while others are less popular but a perfect fit for a specific application.
By the time you read this, President Donald Trump might finally have accepted reality and conceded the election. Or, there might be a coup or a zombie apocalypse; it's been that kind of year.
HAMBURG, Germany—Engineers at the Fraunhofer Institute for Factory Operation and Automation are working with Airbus to learn how to detect and predict disruptions in aircraft production.
