Another Type of Removable Adhesive
The U.S. Air Force had a problem. It wanted an adhesive for temporarily attaching small test packages to the exterior of a jet without mechanical fasteners. Each package weighed only a few pounds, but the adhesive bond had to withstand Mach 2 flight. At the same time, the adhesive had to allow engineers to remove the packages without damaging them or marring the paint on the jet.
Working with a grant from the Air Force's Small Business Innovative Research program, EIC Laboratories Inc. (Norwood, MA) came up with a solution: a high-strength adhesive that disbonds from a metal surface when an electrical current passes across the epoxy-metal interface. Called ElectRelease, the new adhesive is a two-part, amine-cured epoxy.
The typical voltage required to break the bond is 10 to 50 VDC, resulting in a current flow of less than 1 milliampere per square inch of bond line. This low power does not produce heat during disbonding. The parts separate at the positive interface without mechanical, thermal or chemical damage.
The adhesive works with aluminum and its alloys, high alloy steel, carbon steel, stainless steel, copper and titanium.
Because electrical current, in the form of ions, flows through the epoxy during disbonding, electrochemical reactions occur at both the positive and negative interfaces between the adhesive and the metal substrates. How-ever, the electrochemical reactions at the negative interface do not cause disbonding.
Although it is not necessary to use a metal as the negative substrate, it must conduct electrons. For example, carbon-fiber reinforced epoxy composites are suitable negative substrates. If two metal substrates are bonded, disbonding at both interfaces is possible by reversing the polarity of the disbonding voltage.
To bond nonconductive materials or painted surfaces, EIC developed an ElectRelease foil patch. The patch consists of two sheets of metal foil, usually aluminum, laminated with a thin layer of precured ElectRelease. The patches are cut to shape, and any standard adhesive is applied to each surface. The nonmetallic parts are then bonded with the adhesive-coated patch. The parts are disbonded by applying a voltage between the two metal foils. The bond separates at the interface between the ElectRelease and the positive foil.
For more information, call EIC Laboratories at 781-769-9450, visit www.eiclabs.com.
  • Adhesive Bonding: Thermally Removable Adhesive Bonds
  • soy-based adhesive
    Nature Inspires New Type of Adhesive
  • Human Eye Inspires New Type of Camera Lens
    Handbook of Plastics Failure Analysis
  • APPLIED Adhesives
    Since 1971, APPLIED Adhesives has been a trusted industry leader that can meet all your adhesive needs. Our experts source the products, parts, and equipment while providing maintenance services that help you run at optimum efficiency. We provide customized solutions with a cost-in-use approach that saves you time and money.
  • Adhesives Research Inc.
    Adhesives Research is a global leader in providing adhesive design flexibility, fast development capabilities, combined with unique turnkey solutions. Adhesives Research has a broad range of commercially available products and specially developed adhesive and coating platform technologies for the bonding, assembly and functional performance of Medical devices, Electronics and Industrial applications.
