Columns
AIA: Servos, Controllers Empower Tire Assembly
Fori Automation (Shelby, MI) manufactures assembly equipment for automakers throughout the world. To get its new tire assembly machines to market that much quicker, the company uses a control system incorporating the SM-EZMotion servo programming module and Unidrive SP from Emerson Control Techniques (Eden Prairie, MN). This combination cuts application development times to just a few hours. The Unidrive SP's universal feedback device support system also facilitates the use of absolute encoders, which increase the machines' productivity once they are in place on the shop floor.
Tire assembly machines put tires on rims, inflate the tires to correct pressure, and palletize them for shipment to auto and truck assembly lines. Servomotors are used because of their accurate speed and torque control, as well as their small footprint. Servos also make the machines flexible because of their programmability, giving them the capacity for rapid product changeover.
According to Fori controls project engineer Kevin Sproat, absolute encoders operating via the Stegman Hiperface protocol eliminate downtime for adjusting the machine homing upon restart or after E-stops. In addition, absolute encoders don't need to home to a sensor on every power cycle. This avoids the problems that result when sensors fail or are moved out of positional tolerance due to machine vibration.
"The use of absolute encoders more than pays for itself, as we estimate their use could save about an hour of downtime a week," Sproat says. With the tire assembly cycle being 10 seconds, that translates into 300 additional tires being produced each week.
The SM-EZMotion module uses Windows-based PowerTools Pro software, which allows Fori to program a new application with very few lines of code. Specifically, "drag and drop" and "point and click" tools simplify integration of the DeviceNet fieldbus for plug-and-play communication with the PLC and HMI.
Both the SM-EZMotion and SM-DeviceNet modules snap into place inside the Unidrive SP, which can accommodate up to three modules. Because of the Unidrive SP heatsink configuration, Fori was able to achieve optimal thermal design by using through-hole panel mounting. This allowed Fori engineers the flexibility to place drive panels where they wanted on the machine and avoid the expense of adding panel air conditioning.
For more on automation and motion control, call 952-995-8000, visit www.emersonct.com or eInquiry 5.
For more on automated assembly machines, call 586-247-2336, visit www.foriauto.com or eInquiry 6.
You must register or login in order to post comments.
Multimedia
Videos
Image Galleries
Wire Harness
AssemTech Inc. is a busy and growing harness assembly shop in West Chicago, IL. The company has a 12,000-square-foot assembly area and employs 20 full-time harness assemblers - far cry from its early days back in 1986, when founder Chuck Hall and various family members assembled harnesses in his garage.
Podcasts
A Plan to Revive U.S. Manufacturing
In December, the nonpartisan Council on Competitiveness issued a landmark report, Make: An American Manufacturing Movement, that provides dozens of recommendations for addressing the many challenges facing U.S. manufacturers. In this podcast, Jack McDougle, the council’s senior vice president for manufacturing, discusses the council’s vision for reviving U.S. manufacturing. Check out this sneak preview of McDougle’s May 2 keynote address to start Tech ManufactureXPO.
More Podcasts
THE MAGAZINE
Assembly Magazine
may 2012 cover
2012 May
Check out Assembly's May issue!!
TABLE OF CONTENTS SUBSCRIBE
Lean Hang-Ups
By now, most assembly plants have at least tried lean manufacturing. But, some aspects of lean have been easier to implement than others. What tenet of lean has your assembly plant had the most trouble with?
See Poll Results Poll Archive
THE ASSEMBLY MAGAZINE STORE
More Products
Clear Seas Research
Assembly Showrooms
ASSEMBLY Showrooms
STAY CONNECTED
Facebook Twitter  LinkedIn  YouTube
