Columns
Assembly In Action: Gantry Robots Require Little Floor Space to Stack Wheel Sets
As a global leader in the supply of mounted tire and balanced wheel assemblies, T&WA works with many of the world’s major automakers. Not surprisingly, T&WA knows the importance of effective supply chain management.
Each gantry robot in the production Sequencing System sorts incoming tires into vehicle sets and temporarily stacks them beneath the crane structure. Photo courtesy RMT Robotics
As a global leader in the supply of mounted tire and balanced wheel assemblies, T&WA works with many of the world’s major automakers. T&WA has shipped product to assembly plants operated by Chrysler, Ford, BMW, General Motors, Honda, Hyundai and Toyota.
Not surprisingly, T&WA knows the importance of effective supply chain management. The company makes sure its wheel sets arrive in order and just-in-time at their destination.
“Cycle time is everything,” says Tom Sirianno, vice president of engineering for T&WA. “We have a responsibility to ensure our production sequencing system integrates seamlessly with that of our customers.”
Some time ago, Toyota’s increased production demands at the T&WA facility in Paris, KY, threatened to outstrip the capacity of its manual storage and retrieval system. Limited space made it impractical to add more forklifts with clamps. And cost concerns ruled out increasing labor.
Once an electronic order is received, the robots assemble each vehicle set based on tire size and determine whether it requires a steel or aluminum alloy rim. Photo courtesy RMT Robotics
T&WA needed to find a technology that could hold finished goods, provide worker access, and increase production while using limited floor space. To solve the problem, T&WA turned to RMT Robotics, a Canadian firm that designs and installs robotic gantry systems worldwide.
RMT engineers designed a fully automated production sequencing system (PSS) consisting of two high-speed gantry robots that service separate Toyota assembly lines. Each robot sorts incoming tires into five-wheel vehicle sets and temporarily stacks them beneath the structure for later selection and release. After the tire uniformity operation, tires are automatically palletized or streamed into RMT’s gantry-based, cured-tire distribution system.
Computer-controlled, the PSS carries out each shipping task in sequence. Sirianno says T&WA did consider installing other systems that used vertical bins and shelving, but chose the PSS because of its high working speed and promised uptime dependability. Sirianno says the system has operated error-free since being installed several years ago.
For more information on robotic gantry systems, call 905-643-9700 or visit www.rmtrobotics.com.
  • Assembly in Action: Vertical Lifts Free Up Valuable Floor Space
  • Assembly In Action: Robot, Gantry Reduce Welding Times
  • Assembly In Action: I/O Blocks Save Space on Assembly Machine
  • October 30, 2025
  • HowToRobot
