I&J Fisnar-700PTPCW Dispensing Pinch Tube Pen
July 1, 2005
The 700PTPCW pinch tube dispensing pen is an ideal applicator for manually dispensing continuous beads or applying small amounts of low to medium viscosity liquids, such as solvents and cyanoacrylate glues. The disposable pinch tubes are easy to change and offer a low cost alternative to cleaning and replacing valve parts The pinch tube is the only part of the pen that is in contact with the material and discarded when contaminated. The 700PTPCW can be fed directly from gravity or pressurized reservoirs via a wide range of interchangeable fittings.
I&J Fisnar Inc.
2-07 Banta Place
Fair Lawn, NJ 07410 USA
201-796-1477, Fax: 201-794-7034
info@ijfisnar.com
www.ijfisnar.com
eInquiry 542
  • I&J Fisnar-I&J6000 Gantry Cartesian Robots
  • Asian Automakers Feeling the Pinch
  • Know Your Fluids
  • August 14, 2025
  • Fisnar
    DistributorsWISCONSINEllsworth AdhesivesW129 N10825 Washington Dr.Germantown,  WI(262) 509-8773  www.ellsworth.cominfo@ellsworth.com
