Glossary of Ultrasonic Welding Terms
Amplitude: the peak-to-peak excursion of the face of a horn or booster.
Booster: a mechanical transformer used to increase or decrease the amplitude of the horn.
Far field weld: refers to a weld where the distance between the contact surface of the horn and the weld joint is more than 1/4 inch. Ultrasonic energy is transmitted through the upper portion of the part to the joint surface.
Filler: an inert substance added to a resin to modify its physical properties.
Frequency: the number of cycles per second, measured in hertz.
Gain: the ratio of output amplitude to input amplitude of a horn or booster.
Horn: an acoustical tool that transfers mechanical vibrations from the transducer and booster to the parts to be assembled.
Near field weld: refers to a weld where the contact surface of the horn is 1/4 inch or less away from the joint surface. It is important that the horn fits the exact contour of the part to be welded.
Nodal point: the point or points in a booster or horn where little or no linear motion occurs.
Staking: the melting and forming of a plastic stud to retain or lock another material (often dissimilar) in place.
Swaging: used to capture another component of an assembly by melting and reforming a ridge of plastic around the component. The ridge locks the second component in place without welding the two materials together.
Thermoplastic resins: material that can be repeatedly softened and reshaped with heat and pressure. They are ideal for ultrasonic welding.
Thermoset resins: material that cannot be melted or reformed. Hard and brittle, they are not suitable for ultrasonic welding.
Transducer: a piezoelectric device that converts high-frequency electrical energy into high-frequency mechanical vibrations.
Ultrasonic welding: an assembly process in which parts are joined by the local application of pressure and high-frequency vibratory energy.
  • Sonotrode Design Is Key to Success of Ultrasonic Welding of Automotive Assemblies
  • Semi-Automation of Ultrasonic Welding Assembly
  • The Pros and Cons of Robotic Ultrasonic Welding
  • Laser Welding of Plastics
  • Herrmann Ultrasonics Inc.
    Herrmann Ultrasonics is a leading global company in providing ultrasonic welding solutions with five decades of expertise. With our 360° ULTRASONIC ENGINEERING, we offer customer specific support from concept, to high volume manufacturing, to after sales support. We become our customer's trusted advisor and solutions provider for their ultrasonic welding projects. As part of our global network, we have ultrasonic laboratories located in 20 countries, providing local support.
  • Rinco Ultrasonics USA Inc.
    RINCO ULTRASONICS, established in 1976, is a Swiss manufacturer of the world's finest ultrasonic welding and cutting equipment. Specializing in Medical device assembly, Rinco is ISO14385 certified. Rinco's servo driven ultrasonic welder is the fastest, most precise and most user-friendly system available. Contact a Rinco expert for a consultation.
  • Telsonic Ultrasonics Inc.
    The Swiss Telsonic Group has been offering its industrial ultrasonic solutions through representation in Europe, America and Asia since 1966. Constant innovations help to ensure that, in many applications, Telsonic has established a lead over competitors that offers added value to customers. With over 250 highly qualified staff, the owner-managed company specializes in plastic and metal welding as well as ultrasonic cleaning and sieving.
