Columns
AIA: Printer Increases Yield and Throughput
February 7, 2005
Located in the Tianjin Free Trade Zone, HEG OEM Electronics (Tianjin, China) operates 21 automatic insertion machines, seven fully automatic surface mount technology lines and nine manual assembly lines. With this level of investment, the company is able to execute 8.16 million surface mount device placements and 8.68 million insertions each day. The company also operates in-line and functional test equipment to help ensure the quality of its end product.
In past years, the company used dispensing machines to apply adhesives to its printed circuit boards (PCBs), but found that slow application speeds were affecting board throughput. The process also resulted in an unacceptably high defect rate.
To remedy these problems, HEG installed an Infinity screen printer from DEK International (Flemington, NJ), which works in tandem with DEK's PumpPrint process, giving faster throughput and higher process yields.
With the system in place, production defect rates have dropped to around 25 parts per million, as measured by the company's quality assurance program, which includes 2D inspection, visual inspection, automatic optical inspection (AOI) and electrical test. Throughput for boards that require adhesive application has increased to more than 135 boards per hour, and in excess of 81,000 adhesive dots per hour. This latter figure is well within PumpPrint's throughput capability.
"We need to apply adhesive onto a number of our circuit boards for applications such as automotive electronics and consumer electronics products, including DVD and air conditioning systems," says Wang Chong Ji, chief engineer at HEG. "The main advantage of the DEK Infinity printer is that it is simple. It is simple in structure and simpler to operate than competitive systems. This has resulted in a shorter time for maintenance. Also, DEK Infinity printers have a higher repeated accuracy level than some competitive systems."
Another advantage to the system is its ability to operate under harsh environmental conditions. Specifically, it is unaffected by fluctuations in temperature, humidity and glue viscosity.
For more on PCB adhesive dispensing, call 908-782-4140 or visit www.dek.com.
  • Fiber Optics Automation: Improving Cost, Yield and Throughput
  • AIA: Quality Control Increases Throughput
  • Assembly in Action: Fastening Station Increases Throughput
    Scrum Project Management
  • Fishman Corp.
    Fishman® Corporation makes the industry's most advanced fluid dispense systems. The SmartDispenser® features AlgorithmicControl™ and patented AirFree® Technology; innovations that enable manufacturers to assemble products without relying on unpredictable compressed air and error-prone human input. The precision and control gained greatly improves the assembly process, increasing productivity, yields and profits.
  • BBS Automation Chicago
    BBS Automation is a global leader in turnkey automation. We design and build advanced manufacturing systems for life sciences, mobility, energy, and consumer markets—maximizing throughput, minimizing downtime. From design for manufacturing (DFM) to robotics and vision systems, we deliver scalable, Industry 4.0-ready solutions tailored to your exact production needs.
  • Pannier Corp.
    Manufacturer of marking systems for industrial product identification and traceability. Automated systems for every marking need and budget: dot peen pin marking systems, laser systems, marking presses, marking stamps and dies, ink jet printers, flexographic printers, and metal tag and plate marking solutions. Custom system design and full software and integration support.
