Robots Strike Right Tone With Guitar Maker
Taylor Guitars relies on robots to help assemble precision electronics for its world-famous acoustic guitars
Phil Baratti
November 9, 2018
Assembling an acoustic guitar of world-class caliber requires more technology than you might realize. Hand craftsmanship is still the hallmark of Taylor Guitars, which has been in business nearly 45 years.
The hydraulic fluid in pulse tools must be changed regularly
Best Practices for Tool Maintenance
Even the most technologically advanced fastening tools require regular maintenance and calibration
November 8, 2018
Fastening tools are the workhorses of any assembly operation. Consider a high-volume automotive plant. If a vehicle contains 1,000 threaded fasteners and an assembly line is turning out 250,000 vehicles annually, that’s more than 250 million run-downs each year.
ideal assembly
White Goods and Fastener Assembly
What are the most challenging issues that pertain to white goods from the perspective of fastener assembly?
November 8, 2018
In the past, white goods were offered by the manufacturer and the customers, generally, had no design input. However, as the demand for customization increased and the competitive market expanded, manufacturing was under pressure to produce a smarter, more reliable and more attractive product.
Random Bin Picking Comes of Age
New technology enables robots to see and act more like humans.
November 7, 2018
Ordinarily, parts are presented to a robot for pick up at fixed locations, the escapement of a feeder bowl, for example, or the pockets of a thermoformed tray. To save space and eliminate the cost of trays and feeders, manufacturers would like a robot to pick randomly oriented parts out of a bin, box or tote.
Industry 4.0 Maturity Index
A new index provides companies with guidance for carrying out the transformation to Industry 4.0
Bertolt Gärtner
November 6, 2018
Businesses increasingly recognize the growth opportunities offered by digitalization and interconnectedness. These technologies are enabling new business models, efficient use of resources, and cost-effective production of highly customizable products. These developments are collectively referred to as "Industry 4.0."
Options for Pick and Place
As electromechanical units and robots increase in popularity, pneumatic and cam-driven systems remain staples in pick and place operations
November 5, 2018
The No. 1 application for robots, be they Cartesian, SCARA, delta or six-axis models, is also the easiest: pick up a part from one location and place it in another.
Quality Assurance in Wire Harness Production
Manufacturing execution systems reduce error during manual assembly of automotive wire harnesses
Pete Doyon
October 13, 2018
Digitization is an integral aspect of modern vehicle technology. With each successive generation, the implementation of electronic technology continues to rise.
Kanban System Helps Cable Maker Get Lean
Cable manufacturer controls stock replenishment with custom FIFO system
Susanne Kaufmann
October 12, 2018
Auto-Kabel, the global automotive supplier, manufactures cable and lead sets for power supply applications. The friction welding machines deployed in the process must always have an adequate supply of material without excessive safety stocks.
Case Studies in Wire Harness Assembly
These success stories highlight the need to use the latest processing equipment, workbenches and testing systems on the shop floor.
October 11, 2018
Companies measure success in several ways. One of the most important measurements is their number of repeat customers. For wire harness shops, the best way to gain repeat customers is to provide them an ongoing supply of harnesses that are high quality, economical and specifically designed to meet each application challenge.
Anti-Fatigue Mats Keep Workers on Their Feet
Ergonomic mats can reduce the risk of injury and absenteeism in applications that require prolonged standing
October 9, 2018
The statistics relating to musculoskeletal conditions are frightening. In 2012, one of every two adults in the U.S. were diagnosed with some form of musculoskeletal disorder leading to 290.8 million work days lost due to back or neck pain.
Previous 1 2 3 4 5 6 7 8 9 10 11 12 … 286 287 Next
