Columns
Down the Line: Nano Conveyor Belt
August 5, 2004
No matter what type of product is being assembled, conveyors are an essential ingredient of mass production. Scientists at Lawrence Berkeley National Laboratory (Berkeley, CA) have transformed carbon nanotubes into conveyor belts capable of ferrying atom-sized particles to microscopic worksites.
By applying a small electrical current to a carbon nanotube, they moved indium particles along the tube "like auto parts on an assembly line," says Chris Regan, a researcher in the laboratory's materials sciences division. "It lays the groundwork for the high-throughput construction of atomic-scale optical, electronic and mechanical devices that will power the burgeoning field of nanotechnology.
"We're not transporting atoms one at a time anymore-it's more like a hose," explains Regan, who developed the technology with scientists at the University of California-Berkeley's department of physics.
The ability to shuttle a stream of particles to precise locations fills a void that has stymied the efficient assembly of nanostructures. For years, scientists have been able to simultaneously deliver millions of atoms to millions of sites simply by mixing chemicals.
"Although this fast technique has grown quite sophisticated, it remains far too blunt to build atomic-scale devices," says Regan. "It's either all at once, or excruciatingly serial. So we combined incredibly precise localization with something that has higher throughput."
This middle ground is made possible by carbon nanotubes, which are hollow cylinders of pure carbon about ten thousand times smaller than the diameter of a human hair. The research team thermally evaporated indium metal onto a bundle of carbon nanotubes.
The amount of evaporated metal is so small it populates the tubes' surfaces as isolated indium crystals, instead of uniformly coating them. The bundle is then placed inside a transmission electron microscope, where a tungsten tip mounted on the end of a nanomanipulator approaches one nanotube.
After physical contact is made between the tip and the free end of the nanotube, voltage is applied between the tip and the other end of the nanotube, creating a circuit. This sends an electrical current through the nanotube, which generates thermal energy that heats the indium particles.
"If the voltage and thermal energy is carefully controlled, something strange occurs," says Regan. "Real-time video of the nanotube's surface captures an indium particle as it disappears, while the particle to its right grows. Several seconds later, that newly enlarged particle also disappears, replaced by another even further to the right. Like squeezing the last bits of toothpaste from a tube, particles to the left become smaller while those to the right grow."
In this manner, the thermally driven indium atoms inchworm along the nanotube, momentarily occupying a reservoir where a particle is located, and then moving to the next, until all of the indium piles up at the end of the nanotube. In the future, this nano-sized conveyor belt could be aimed anywhere scientists want to deliver mass atom-by-atom. And, if the voltage is slightly increased, the indium's temperature increases and the metal moves from left to right more quickly.
"It's the equivalent of turning a knob with my hand and taking macroscale control of nanoscale mass transport," explains Regan. "And it's reversible: We can change the current's polarity and drive the indium back to its original position."
Regan says indium can be repeatedly moved back and forth along the nanotube without losing a single atom. Nothing is lost in transit. This conservation of mass occurs because the atoms don't evaporate from the system during their journey. Instead, the atoms hug the nanotube's surface as they move, tethered by a process called surface diffusion.
"In order to build a structure we have to be able to transport material to the construction site, and we're developing a better way to do that," says Regan. "Our nanoscale mass delivery system is simple and reversible. It requires only a nanotube, a voltage source and something to transport."
  • Down the Line: Organic LEDs Light the Way to the Future
  • Down the Line: Self-Assembling Car of Tomorrow
  • Down the Line: GM Sees Fuel Cells in the Near Future
