Autonomous & Electric MobilityAerospace AssemblyAV/EM NewsElectrification
SAE Unveils Electric Aircraft Wiring Standards
May 7, 2021
WARRENDALE, PA—SAE International has released two new standards that address the trend of electrified aircraft using higher voltages for systems and propulsion. The goal of SAE AIR7502: Aircraft Electrical Voltage Level Definitions and SAE AIR7506: Impact of High Voltage on Wiring is to help engineers mitigate the effects of increasing electric power demand on board planes.
“As aircraft programs implement scaled-up electrification, SAE International is deeply engaged in providing industry standards in the area of high voltage, which is an essential centerpiece for hybrid and electric aircraft across various aircraft segments,” says David Alexander, director of aerospace standards at SAE International. “With the possibilities new propulsive technologies and systems bring, standards defining appropriate voltage levels for integration on electrified aircraft and in ground operations are essential for industry cohesion.”
AIR7502: Aircraft Electrical Voltage Level Definitions reviews and analyzes aircraft voltage levels to set an industry baseline for future programs utilizing high voltage. The document also provides a rationale for each voltage level. By defining appropriate levels for electrified aircraft, this standard is essential to achieving better aircraft efficiency by reducing weight through high voltage.
AIR7506: Impact of High Voltage on Wiring focuses on how long-term exposure of high voltage impacts round wire insulation life. It documents high-voltage test methods and test methodology. Laboratory results are provided on selected wire insulation systems. Basic failure mechanisms associated with high-voltage impact on insulation systems and lessons learned in designing high-voltage systems are also reviewed.
“With exciting advancements in the industry pointing to multi-megawatt power, high voltage allows for the introduction of more power-dense solutions,” explains Alexander. “These standards will assist the industry in designing safe and interoperable electrical systems.”
KEYWORDS: electric aircraft electric propulsion for airplanes
  • Rules for Routing Aircraft Wiring
  • GKN Aerospace recently completed the first high-voltage electrical wiring interconnection system (EWIS) for the European Union’s Clean Aviation SWITCH project.
    High-Voltage Wiring Harness to Support Electric Aircraft Project
    Electric Aircraft Take to the Skies
  • assembly march 2020
    ASSEMBLY March 2020 Issue
