Home » Topics » Web Exclusive Stories
Web Exclusive Stories RSS Feed RSS
Advanced Drivetrain Technology Makes Wind Turbines More Efficient
February 26, 2010
A new type of transmission technology uses a variable-speed rotor to maximize power capture. It also contains fewer parts than traditional technologies, which allows it to be built with a high-volume, low-cost assembly process.
Product Teardown in the Classroom
February 23, 2010
For more than a decade, students at Massachusetts Institute of Technology have been learning about product teardown. However, it’s only been in the last five years that they’ve been doing actual teardowns.
Deep Disassembly
February 22, 2010
How deep can one dive when disassembling (i.e., tearing down) a product? It will vary depending on the product and amount of information desired by the manufacturer.
Wind Turbines Demand Reliable Components
February 18, 2010
It takes more than a tall tower and a few huge blades to make a wind turbine go. Hundreds of different components are required, such as gearboxes, generators, shafts, bearings, sensors, motors and controllers.
The Pros and Cons of Robotic Ultrasonic Welding
February 5, 2010
Robotic ultrasonic welding can be used to join metal or plastic parts. The technology is ideal for some applications, such as welding battery packs, but may not be difficult to justify for other projects.
Adhesives and Tubing
January 22, 2010
Although plastic medical tubing can be joined to itself, it’s often attached to a device, bag or connection. As medical device manufacturers look for alternatives to traditional solvent welding, demand for adhesives is increasing.
Best Practices for UV-Cure Adhesives
Plastic Tubing Bonding Tips
January 20, 2010
Medical tubing is made from several types of plastic, including polyvinyl chloride (PVC), polyethylene, thermoplastic elastomers, nylon and silicone. Traditionally, PVC is most widely used, because it bonds easily with other plastics. However, non-PVC tubing is often more difficult to bond.
Automated Tube Assembly Is Easier Said Than Done
January 20, 2010
Traditionally, plastic medical tubing is manually attached to valves, connectors, catheters, and other devices. But, medical device manufacturers are eager to automate the assembly process. It’s being driven by several trends, such as labor shortages, labor costs and increased levels of quality control.
Capital Equipment Spending Survey Method and Demographics
December 4, 2009
Here's a look at the numbers behind the data for our 14th annual capital equipment spending survey.
Ball Chairs-Fad or Fabulous?
December 1, 2009
Many grammar schools around the United States are using ball chairs in the classroom. The devices force students to frequently change positions to maintain balance. That leads to increased alertness and concentration. Ball chairs can be modified with wheels, arm rests and back supports for assembly line applications. However, the devices have pros and cons.
Previous 1 2 … 15 16 17 18 19 20 21 22 23 … 60 61 Next
