Assembly in Action: Towline Improves Tractor Assembly
January 31, 2007
At its manufacturing facility in Fargo, ND, Case New Holland (Amsterdam, Netherlands) performs final assembly of its heavy-duty, articulated agricultural tractors. Weighing 60,000 pounds, the machines have long presented a material handling challenge as well as a challenge for safe, efficient assembly.
Leading Lean: From Dabbling to Commitment
January 31, 2007
Get a purpose, take away the crutches, ask how well you’re doing, and you can move from dabbling to commitment!
Bonding Lines: Cyanoacrylates for Assembly
Dr. George W. Ritter
January 30, 2007
Wouldn’t an adhesive that bonds to everything, cures instantly, survives temperature extremes and never breaks be a super glue? Well, almost.
Assembly Innovations: Capaciflectors Guide Robots to Bolt Heads
January 1, 2007
Vision systems are excellent for guiding robots. However, for some applications, such as tightening bolts, a vision system is of little help, because the end-effector and tool are so close to the fastener they block the camera’s view.
Assembly Innovations: Device Monitors Curing of Epoxies
January 1, 2007
To get bonded assemblies out the door as quickly as possible, researchers at NASA’s Langley Research Center have developed a noninvasive system for monitoring the cure status of epoxies and other resins.
Assembly Innovations: New Process Assembles Flip Chips Faster, Better
January 1, 2007
A new process for assembling flip chips promises to reduce warpage, eliminate voids and cut cycle times by 50 percent.
Assembly Innovations: Custom Screws Assemble High-Security Applications
January 1, 2007
Tamper-proof fasteners are intended to keep the average Joe from, well, tampering with an assembly. For most applications, that’s good enough, but not all.
Assembly Innovations: Tiny Sensor Checks LEDs
January 1, 2007
Let’s say you have circuit board assembly that contains red and green LEDs. Automated optical inspection can tell you if the LEDs are present and oriented correctly. But how tell if a green LED has been accidentally swapped with the red one?
Assembly Innovations: Device Feeds, Installs Rivet Nuts Automatically
January 1, 2007
Most fasteners that provide permanent load-bearing threads in thin materials require both sides of the workpiece to be accessible during installation and final assembly. When the workpiece can only be accessed from one side, threaded rivet nuts and studs provide a solution.
Assembly Innovations: Rugged Cordless Tools Feature Innovative Charger
January 1, 2007
Although cordless tools are becoming increasingly popular on assembly lines today, many manufacturing engineers continue to view them with suspicion. And that’s too bad.
Previous 1 2 … 141 142 143 144 145 146 147 148 149 … 222 223 Next
