X-Y-Z: New Network Combines Best of Ethernet, SERCOS
October 6, 2005
SERCOS III enables the motion controller to communicate with higher-level devices.
Assembly Lines: Toyota Fuels U.S. Job Growth
October 6, 2005
Turns out that what's good for Toyota is also good for the country.
AIA: Software Cuts Tuning Times
October 6, 2005
Tuning hydraulic systems can be a frustrating trial-and-error process. It is not always clear how changing one control parameter will affect the function of the system.
Uncommon Sense: Ready to relocate? Bet not!
October 5, 2005
Relocating a plant is not for the faint of heart. Approach with trepidation; you might be just as well off where you are!
Editorial: R&D Paves the Way
October 4, 2005
Perhaps not so obvious is the importance of R&D to manufacturers not generally regarded as high-tech.
Assembly Innovations: See the Torque
September 21, 2005
Motor vehicles and aircraft are held together by large numbers of threaded fasteners....Failure of these fasteners can be catastrophic and incorrectly torqued fasteners are a prime failure mechanism.
Uncommon Sense: Is There Any Hope?
September 6, 2005
Corporate distress may appear to come on quickly and with little warning. In most cases, however, management ignored one or more of these warning signs.
AIA: Compactor Helps Boat Maker Stay Afloat
September 6, 2005
Commitment to quality and customer satisfaction is not just an ideal, but a corporate policy for Sea Ray (Knoxville, TN), a manufacturer of pleasure boats.
AIA: Linear Actuators Cut Programming, Assembly Times
September 6, 2005
Exselect Engineering (Toronto) manufactures automated soldering equipment. Its products range from lab-scale machines to multistation turnkey systems for Tier 1 automotive suppliers.
AIA: Labeling System Streamlines Cable Assembly Process
September 6, 2005
Nortech Systems Inc. (Wayzata, MN) produces wire harness and cable assemblies for a vast array of applications. The company assembles more than 1 million cables annually.
Previous 1 2 … 155 156 157 158 159 160 161 162 163 … 222 223 Next
workstation
