White Papers
What’s Missing from Manufacturing Data
data from manufacturing systems
Image: Aegis Software
May 7, 2026
Manufacturing data is often incomplete, inconsistent, or disconnected.
Most teams deal with that every day. You end up pulling information from different systems just to figure out what happened, and even then, it is not always clear.
This paper looks at why that keeps happening. A lot of it comes back to how the data is set up in the first place. If those links between machines, materials, and the actual process aren’t there from the start, things get messy quickly.
That’s where AI runs into trouble too. It can only work with what it has. If the data is coming in pieces, you might get patterns, but not much explanation behind them.
Once those connections are in place, it’s a different story. You can follow what happened, see how one event led to another, and make a call without having to dig through multiple systems to double-check it.
The paper walks through a few examples that show the difference. Same underlying data, but very different outcomes depending on how it is structured. Aegis Software logo
Download the whitepaper
Aegis Software
Website: www.aiscorp.com
Phone: +1 215 773 3571
Email: info@aiscorp.com
KEYWORDS: manufacturing data
  • Feds Investigate Report of Weapons Missing From Assembly Plant
  • Data Exposed 7-25
    More Than 150 Gigabytes of Manufacturing Data Found Exposed on Web
  • Translating Manufacturing Data for the IIoT
  • September 16, 2025
