White Papers
Ensure Success When Switching From Conventional Lamp to LED Light-Curing Sources
dymax
Dymax
December 1, 2016
The white paper “Ensuring Success When Switching from Conventional Lamp to LED Light-Curing Sources” discusses topics such as how LED curing works, the advantages of LED curing, and getting enough information to switch successfully. LEDs, or light emitting diodes, continue to gain popularity as a replacement for traditional light bulbs, not only in homes and public buildings, but also for use with light-curable materials (LCMs). Because of the differences in the technology, making the switch from broad spectrum to LED-curing energy sources is seldom a matter of simply replacing conventional lamps with LED units.
Switching to an LED system depends on careful consideration of all the factors involved, from the LCM to the curing unit selected for the application. With attention to detail and proper compatibility of all components, along with sufficient adjustments to manufacturing processes, it is possible to achieve a successful transition to LED light-cure technology.
Dymax Corporation
Website: www.dymax.com/ledtechnology
  • UV LED Lamp Cures up to 100 Optical Lenses per Hour
  • Firms to Build LED Assembly Plant
  • Excelitas
    Excelitas offers customers the full spectrum of solutions from UV to IR, supporting a wide range of applications. As a single source provider, the Excelitas portfolio includes UV lamps and systems, UV LED spot and area curing systems, UV microwave, Infrared emitters and systems, and medium pressure UV lamps.
  • Excelitas Technologies
    Excelitas Technologies®, offers customers the full spectrum of solutions from UV to IR, supporting a wide range of applications. As a single source provider, the Excelitas portfolio includes UV lamps and systems, UV LED spot and area curing systems, UV microwave, Infrared emitters and systems, and medium pressure UV lamps.
