The new, compact C4 six-axis robot from EPSON Robots can perform a standard cycle—move a part 1 inch up, 12 inches across, 1 inch down, and back again—in just 0.37 second.
Every year, fans of the Winter X games see snowmobile racers battle the elements and the laws of gravity to perform amazing feats—including long distance jumps and double back flips. What the fans don’t see is the ongoing battle between fasteners and vibration within every bolted joint of the snowmobile.
Manually assembling small parts isn’t that difficult. Inserting a screw into a hole or a wire into a connector is simply a matter of hand-eye coordination. Assembling larger parts, like, say, the multiton fuselage sections of a jetliner, is whole other matter.
Methods Machine Tools has built top-notch automation equipment in North America since the late 1950s. It has seven regional technical centers across the United States, including one in Wixom, MI, that focuses on automotive applications.
Arenas and other large venues rely on high-tech displays to produce the best show possible for an audience. The show must go on, as the saying goes, so reliability is paramount.
