We Fed It: Bowl Provides Ideal Solution
April 29, 2010
Homer City Automation built a vibratory bowl and track to feed tips for medicine droppers.
Automation Profiles: This Assembly System Has the ‘Write' Stuff
April 29, 2010
Systems integrator Orientech Inc. recently designed an automated assembly system for surgical pens. The system assembles pens at a rate of 120 per minute.
The Editorial: A Speed Bump on the Road to Green
April 29, 2010
In our attempt to free ourselves from dependence on Middle Eastern oil, we may very well have become just as dependent on Chinese mineral deposits.
Fastening Threads: More Data, Less Knowledge?
David Archer
April 29, 2010
Just as both the quality of the joint and the quality of the joint designer’s knowledge base will be limited by reliance on numerical analysis, the same limitations occur when experience and applied experimentation is all one has to draw from.
Assembly In Action: Mobile Workstation Increases Efficiency
March 29, 2010
Hol-Mac wanted to increase technician efficiency in its plants by making test equipment and computers more mobile. This mobility would let technicians bring equipment to areas throughout the four facilities as needed, rather then walking back and forth endlessly to static workstations.
Assembly In Action: Laser-Sintered Parts Meet Tight Tolerances
March 29, 2010
Until recently, Northwest UAV Propulsion Systems ordered aircraft components from an outside vendor and performed sanding and other finishing processes on them prior to manufacture. However, the parts purchased were often of an inconsistent quality, so NWUAV decided to manufacture them in-house to ensure their high quality.
Assembly In Action: Process Helps GM Holden Seal in High Standards
March 29, 2010
Engineers at Holden, the Australian subsidiary of General Motors, needed a high-performance seal between the door and quarter window of the Holden VE Ute coupe. The seal could not have separate fixing components.
Assembly In Action: Vision-Enabled Vibratory Bowl Feeder Handles 400+ Parts
March 29, 2010
Rixan Associates Inc. needed to improve the flexibility of its vibratory bowl feeder system if it hoped to win the business of a fastener manufacturer, which was manually loading 415 aerospace fasteners into a press.
Moving Forward: New Factory Keeps Nova Bus Rolling
March 29, 2010
The next time a harried commuter gets on a bus in New York City, he can take some solace from knowing that the vehicle was made just 320 miles away at Nova Bus’ new assembly plant in Plattsburgh, NY.
We Fed It: System Sorts, Orients Plastic Vials
March 29, 2010
A medical device manufacturer needed to orient and sort empty, 2-milliliter plastic vials, count them, and place them on a tray in rows of 12 by 25 for final packaging in cartons. Read how it was done.
Previous 1 2 … 106 107 108 109 110 111 112 113 114 … 222 223 Next
