Assembly in Action: Monorail System Streamlines Clean Room Operations
February 23, 2010
Medical device manufacturer Maquet Cardiopulmonary AG has optimized cycle time on its line by connecting assembly stations with the Montrac transport system from Montech AG.
Moving Forward: New Plant Helps Philips Focus on Healthcare Niche
February 23, 2010
Philips Respironics isn’t resting on its laurels in the healthcare market, as evidenced by the opening in April 2009 of a $32 million plant in Murrysville, PA, devoted to high-volume, low-mix production of special devices used to treat obstructive sleep apnea.
Assembly in Action: Vertical Lifts Free Up Valuable Floor Space
January 28, 2010
Bauer Compressors needed a way to more effectively manage its growing parts inventory and add floor space at its assembly plant.
Assembly in Action: Roller Thrust Bearings Solve Car Seat Challenge
January 28, 2010
Engineers at bearing manufacturer Hartford Technologies helped GM improve the drive gear assembly for a seat adjuster.
Assembly in Action: Panel PCs Handle Heavy-Duty Lifting Chores
January 28, 2010
When designing a new heavy-duty transporter, engineers at TDS Automation didn't have much room for the controller. A tablet PC solved the problem.
Assembly in Action: Lean Material Handling Plays a Leading Role
January 28, 2010
Workstations, flow racks and conveyors take center stage for an assembler of movie lighting.
Leading Lean: Salvage Your Waste
January 28, 2010
A great lean thinker has a lens for value.
We Fed It: Sealed Drive Feeds Primers Safely
January 28, 2010
An ammunition manufacturer needed to feed primers, the cylindrical brass parts used to light the propellant in projectiles. Automation Devices Inc. hit the target.
Automation Profiles: Cabinet Assembly Moves Into 21st Century
January 28, 2010
Robots are taught how to pick up wooden parts that vary in size, density and orientation.
The Editorial: Protect Hearing on the Line
January 27, 2010
More than 22 million U.S. workers are exposed to noise levels that put them at risk for hearing loss. Plant managers are obligated to protect their workers' hearing.
Previous 1 2 … 108 109 110 111 112 113 114 115 116 … 222 223 Next
