Home » Topics » Industries » Appliance Assembly
Appliance Assembly
Appliance Assembly RSS Feed RSS
speed nut
Specialty Fasteners
January 1, 2001
Nuts and bolt aren't the only types of fasteners used in product assembly. Retaining rings, Speed Nuts and a variety of other specialized metal and plastic fasteners have been developed. These specialty fasteners can often save time in the assembly process, eliminate the need for additional fastening components, lower manufacturing costs and maximize holding power.
Test and Inspection
Advanced Leak Test Methods
Hemi Sagi
January 1, 2001
LEAK TESTING IS AN engineering challenge. On one hand, engineers must meet stricter leak rate standards. On the other, they have to make the leak testing process less costly and less dependent on operator skill. To meet this dilemma, engineers must understand all aspects of the leak testing process.
Fastening Solutions for Thin-Walled Applications
August 2, 2000
As wall thicknesses are decreasing, new fastening techniques are in development to address the potential problems these assemblies can present.
Assembly by Die Casting
June 27, 2000
Assembly by Die Casting is used as the joining medium to assemble multiple small components up to 6 in. (150 mm) in diameter, and as the production method to form additional components directly on the assembly.
Structural Bonding
Norman Remich
June 5, 2000
Structural adhesives are designed to bond metal to metal or to plastic, fiberglass or other substrates. Typical adhesives include two-component epoxies or modified acrylics.
Ultrasonics Replace Solvent Bonding
Norman Remich
June 5, 2000
Ultrasonic technology is providing Lasko Products with reliable, consistent bonding in the assembly of reservoir jugs for its humidifiers and other household appliances.
Fewer Parts, Quicker Assembly
Norman Remich
June 5, 2000
In appliance applications where access to a unit or disassembly for service may be required, specialized types of self-clinching fasteners have been developed.
Previous 1 2 … 48 49 50 51 52 53 54 55 56 Next
