Home » Topics » Industries » Appliance Assembly
Appliance Assembly
Appliance Assembly RSS Feed RSS
Do Your Fasteners Need a Preapplied Thread-Locker?
Stephen A. Smith
June 27, 2008
Thread-lockers keep fasteners from loosening due to vibration. Here are insights into how, why and when to use fasteners with preapplied thread-lockers.
Automatic Adhesive Dispensing Equipment Provides High Repeatability for Manufacturer of Stove Parts
April 18, 2008
American Stove Parts (Temecula, CA) manufactures components for gas cook stoves, including fil-ters, tube assemblies, injection molded components, valves, fittings, door gaskets and burner knobs.
Conformal Coatings Protect Electronic Assemblies
Bill Boyd
March 24, 2008
Conformal coatings protect electronic assemblies from the elements.
Joining: Think Zink
January 31, 2008
Molten zinc alloy is not commonly considered as an instant curing “glue,” nor as an alternative to instant-cure adhesives for bonding small components. But it has been used for more than 60 years in FisherTech’s Injected Metal Assembly (IMA) process to join components in much the same way as adhesives. While zinc alloy can’t replace adhesives in all applications, it can do so in many assemblies without the problems of peeling and thermal degradation inherent with conventional adhesives, and without the need for special surface preparation.
Joining: Failsafe Fusing
Chookazian Steven M.
August 1, 2007
There are many critical plastic-part assembly applications where the long-term integrity of the joint is absolutely essential, such as when the assembly must contain a liquid. Examples include various small household appliances, oral hygiene appliances, or parts for major appliances, such as a dishwasher arm or clothes washer pump assembly.
Joining: Better Bonding
February 1, 2007
Combining materials of choice is important for the appliance industry where “form follows function” is archetypal. Appearance, performance, cost, and assembly ease constantly dog the engineering community in this industry. This is particularly true when joining dissimilar materials, such as metals and plastics, into one unit or subassembly.
Dow Corning hot-melt adhesive
Adhesive Bonding
New Adhesive Combines Silicones and Hot-Melts
Silicone reactive hot-melt adhesive is ideal for bonding low-surface-energy materials and dissimilar substrates.
Dr. Steven R. Block
January 1, 2007
Fixturing for Leak Testing
Adam Cort
December 1, 2006
Every leak test system has one thing in common: The product being tested must be effectively sealed and fixtured.
JOINING: Pivotal Point
August 1, 2006
When an application requires two thin metal sheets to be joined permanently face-to-face, designers routinely have turned to rivets, welding, or adhesives and tapes. But tradeoffs loom with each of these methods. An innovative fastener design using clinch technology provides a more practical and less complicated joining method that is able to perform multiple functions and expand design possibilities.
SWITCHES & RELAYS: Cut the Chatter
August 1, 2006
Recent developments in electronic equipment have led to technically advanced appliances that require progressive electronic technologies.
Previous 1 2 … 48 49 50 51 52 53 54 55 56 Next
