Home » Topics » Industries » Appliance Assembly
Appliance Assembly
Appliance Assembly RSS Feed RSS
Dyson Invests $15 Million in Michigan Battery Company
March 18, 2015
ANN ARBOR, MI—Battery start-up Sakti3 has lured a $15-million investment from vacuum cleaner manufacturer Dyson, which is hunting for technology to improve the battery performance of cordless vacuums and other devices.
ORNL, Whirlpool Collaborating to Design Energy-Efficient Fridge
March 10, 2015
OAK RIDGE, TN—The Department of Energy’s Oak Ridge National Laboratory and Whirlpool Corporation are collaborating to design a refrigerator that could cut energy use by up to 40 percent compared with current models.
Infrared Welder Assembles Cylindrical Plastic Parts
March 3, 2015
Welded plastic cylinders are the lifeblood of British manufacturers Harvey Softeners Ltd. and Wavin Ltd. Harvey produces pressure tanks for its water softeners, while Wavin makes plastic tubes that connect to below-ground drainage systems.
Chinese Appliance Manufacturer Embraces Robotic Assembly
March 3, 2015
SHUNDE, China—Chinese appliance manufacturer Midea Group employs robots for most assembly jobs, leaving only the final checks and testing to humans.
RefrigerationPressFittings_FT
Refrigeration Press Fittings
March 2, 2015
RLS LLC, a Marmon/Berkshire Hathaway company, announces the launch of RLS Refrigeration Press Fittings, the world’s first press-to-connect fittings engineered for high-pressure copper refrigeration connections.
U.S. Unions Poised for Comeback
February 20, 2015
LOS ANGELES—After years of avoiding confrontation, the U.S. labor movement is reasserting itself. From the car plants of Detroit to the ports of Los Angeles, unions are demanding payback for sacrifices they say helped revive the economy.
NoiseVibrationControl_FT
Passive Noise Reduction Options for Axial and Centrifugal Fans
Learn more about controlling operating noise.
February 2, 2015
In applications relating to refrigeration, air conditioning and ventilation technology, users frequently notice that the selected fan installed in the device does not run as quietly as expected.
Whirlpool to Use Wind Turbines to Power Findlay Facility
January 27, 2015
FINDLAY, OH—Whirlpool Corp. is using wind energy to power its assembly plant here. Two wind turbines will supply approximately 22 percent of the plant’s electricity.
Dyson to Build R&D Center
January 22, 2015
MALMESBURY, UK—Appliance manufacturer Dyson Ltd. is building a new R&D center here to support its growing electronics design activity.
Hoffmann on Testing
Don’t be Dazzled by Claims of Superior Testing Software
Jacques Hoffmann
January 19, 2015
If someone tells you his leak test system is superior because of its control software, kick the tires, so to speak. In many, if not most, applications, it is the hardware, not the software, that makes or breaks the ability to get high throughput without compromising gauge R&R.
Previous 1 2 … 29 30 31 32 33 34 35 36 37 … 55 56 Next
