Multifactor Productivity Rises Again
January 1, 2001
WASHINGTON--Multifactor productivity in manufacturing increased for the seventh consecutive year, according to the U.S. Bureau of Labor Statistics.
Multifactor productivity measures the joint influences on economic growth of technological change, efficiency improvements, returns to scale, reallocation of services and other factors. Unlike labor productivity, which is measured in output per hour, multifactor productivity requires information on capital services and other data that are not available on a quarterly basis.
Multifactor productivity has not declined since the recession year of 1991. In 1998, the most recent year for which statistics are available, multifactor productivity in manufacturing increased 3.1 percent. Although that's slightly less than the 3.4 percent growth rate recorded in 1997, the increase was still much larger than the average over the postwar period.
The 1998 gain in multifactor productivity was the result of a 5.9 percent advance in output, less a 2.7 percent increase in combined inputs. Output growth was the most rapid since 1984, and the pace of growth of combined inputs was faster than in the previous 3 years.
In comparison, multifactor productivity for all private, nonfarm businesses increased only 1.5 percent in 1998.
  • U.S. Productivity Rises Again
  • Productivity Rises at Fastest Pace in Years
  • U.S. Productivity Increases Again
  • achieving
  • A'Gain Digitech Pvt. Ltd.
    A' gain Digitech is a technology company with specialized solution A'Gain Smart Board 1 : The ASB 1 is an embedded system developed to transform the wire harness assembly process. It is a tech-forward, practical & versatile solution to the challenges posed by traditional assembly boards. Wire harness manufacturing anchored on the ASB 1 delivers excellent results for productivity, capacity building & scalability. QUAD 64 Quad 64 is a technology product developed to simplify and enhance wire harness testing processes across enterprises. The apparatus is a compact, integrated, and interconnected system supported by a software-based Data Management dashboard with an intuitive GUI. A first-of-its-kind patented product that is poised to disrupt & revolutionize harness testing.
  • Flow Products
    For over seventy years, Flow Products has been a leading distributor and integrator of pneumatic, hydraulic and electro-mechanical products in the Chicago and mid-west region. Our product offerings range from fittings, valves, motors, pumps, actuators, sensors to a full array of custom manifolds and engineered systems – all designed to improve our customer’s productivity.
