TechnologiesNew ProductsTest and Inspection Assembly
New & Noteworthy
Smart 3D Sensor Provides High-Speed, High-Res Images
LMI Technologies Gocator 4000 smart 3D coaxial line confocal sensor
Image courtesy of LMI Technologies Inc.
September 19, 2024
The Gocator 4000 smart 3D coaxial line confocal sensor provides high-speed, high-resolution, and shadow-free inline inspection with outstanding angular range (maximum slope angle ±85 degrees). The sensor is ideal for inspection applications in various industries, including semiconductor, consumer electronics and EV battery.
The sensor provides 1,920 points per profile for high-resolution, shadow-free 3D measurement and inspection. The sensor is available with a resolution of up to 1.9 microns and a field of view up to 5 millimeters. Speeds of up to 16 kilohertz are possible at limited measurement range, and speeds of more than 4 kilohertz are possible at full measurement range.
The coaxial optical design allows the sensor to scan simple and complex surface topologies with zero shadowing effect for improved data quality and more accurate measurement results on steep-angled features (such as step height of PCB chips), deep grooves (such as wafer die fractures), and protruding components (such as wire bonds on integrated circuits). The optics also deliver outstanding angular range for inspecting on highly curved surfaces (such as the chamfer of cell phone display glass).
lmi3d.com
KEYWORDS: machine vision systems
  • HiCube Neo vacuum pumping station
    High-Speed Vacuum Pump
  • Model BWH high-speed rotary bearing
    High-Speed Rotary Bearing
  • WEISS North America's DR series delta robot
    New Delta Robot Designed for High-Speed Applications
    Functional and Smart Materials
