Automation Profiles: System Assembles Nuclear Implants for Life-Saving Cancer Therapy
September 29, 2009
Assembly stations are located in a sealed box filled with 100 percent argon.
We Fed It: Bowl Feeds Needle Hubs
September 29, 2009
Clean room manufacturing process required a stainless steel vibratory bowl.
The Editorial: Turnabout Is Fair Play
September 29, 2009
A growing number of assemblers are moving their production operations back to the United States from overseas.
Assembly in Action: Vision System Verifies Spec Motor Codes
September 29, 2009
Each of the major parts in the new motor has a 2D bar code that can be read in seconds by a handheld scanner, greatly reducing inspection time at the track. These marks must be positioned in specific, often difficult-to-mark locations so that officials can easily check the parts either before of after a race to prevent cheating.
Assembly in Action: Modular Air Filters Cut Costs
September 29, 2009
F&P Georgia manufactures subframe and suspension components for Honda and Nissan. The firm runs extensive welding, stamping and painting operations in its 200,000-square-foot facility in Rome, GA.
Assembly in Action: Components Facilitate Design, Construction
September 29, 2009
Betz Contracting & Machining designs and builds custom turnkey machines, automated assembly fixtures and quality control fixtures for a number of Tier 1 suppliers in the automotive industry.
Assembly in Action: Welding Cell Three Times Faster Than Operators
September 29, 2009
Having two fixtures allows the robot to be in constant use
Leading Lean: Turning Thinking Into Action
September 29, 2009
An action plan is one of the most important parts of an A3 report. Turning ideas and conversations into crisp, focused action plans is something every lean leader needs to do.
dymax 900
Bonding Lines: How Good Is Good?
Dr. George W. Ritter
September 28, 2009
One of the biggest questions surrounding structural adhesives is, “How do I know the bond is good?” Bonded joints are tested under many conditions during development, but those tests are destructive tests. New types of nondestrutive testing allow engineers to detect kissing disbonds.
Assembly In Action: Robots Weld Parts in Small Batches
August 31, 2009
Unlike many assemblers, the company fabricates about 85 percent of the parts it uses. Parts are often made in small quantities-sometimes as few as one at a time-to meet real-time demand on the assembly line.
Previous 1 2 … 112 113 114 115 116 117 118 119 120 … 222 223 Next
