Assembly in Action: Automated Leak Tester Provides Precision, Traceability
April 22, 2009
Among other improvements, Eaton wanted to incorporate a real-time test data system that could be fully integrated with its plant-control network to facilitate government tracking and record keeping.
Assembly in Action: Rivets Ensure Quality Seat Assembly
April 22, 2009
The placing heads then close horizontally, simultaneously inserting the rivets and brackets into the holes of the harp. Afterward, they extract the stems and return to a home position.
Leading Lean: Ban the Hockey Stick!
April 22, 2009
Hockey stick behavior is such a serious manipulation of the numbers that manufacturers should have to report it in the footnotes of their public financials.
Editorial: Planting the Seed Corn
April 21, 2009
Industrial research and development programs are the seed corn of product innovation. Unfortunately, one of the first cost-cutting measures some companies take when faced with the challenge of a recessionary economy is slashing their R&D programs.
Down the Line: An Underwater Energy Source
March 31, 2009
Engineers at NASA’s Jet Propulsion Laboratory (JPL, Pasadena, CA) have created a system that uses water motion to generate a high-pressure liquid, which is then transported to shore and used to produce electricity on land. It  eliminates all submerged electrical components, which are subject to corrosion.
Down the Line: Smart Lighting Is Energy Efficient
March 31, 2009
Researchers at Rensselaer Polytechnic Institute (RPI, Troy, NY) have developed a new type of light emitting diode (LED) that features significantly improved lighting performance and energy efficiency. The polarization-matched LED exhibits an 18 percent increase in light output and a 22 percent increase in wall-plug efficiency.
Down the Line: Thin, Flexible Solar Power
March 31, 2009
A new type of solar cell is so thin and flexible that it can be mass-produced like paper currency. The printable cells offer a number of advantages over traditional solar panel technology. For instance, they are lightweight and easily transportable, making them attractive to a domestic market and also flexible like a banknote.
Down the Line: Simulation Software Aids Assembly
March 31, 2009
A new software program that simulates assembly paths has been developed by engineers at the Fraunhofer Institute for Industrial Mathematics (ITWM, Kaiserslautern, Germany). By using the software, components that only exist in the form of CAD data can be virtually installed in a new car model.
Down the Line: Carbon Nanotubes Build Strong Airframes
March 31, 2009
Nanotechnology may help aircraft manufacturers produce airframes that are lighter and stronger than ever. Researchers at the Massachusetts Institute of Technology (MIT, Cambridge, MA) are reinforcing the plies used in advanced composites by stitching them with nanotubes.
Welding Beads: Welding Rods and Wires
Sam Lewis
March 27, 2009
Resistance and other solid-state welding processes are ideal for joining metal wire or rod to form rigid structures.
Previous 1 2 … 117 118 119 120 121 122 123 124 125 … 222 223 Next
