Automation Profiles: System Assembles Family of Car Latches
January 26, 2009
With the right layout and some clever engineering, automation systems can assemble families of similar products relatively easily.
Assembly in Action: Wire-Harness Audit Improves Productivity
January 26, 2009
Advanced Interconnect Manufacturing (AIM-Rochester, NY) produces cable assemblies, wire harness assemblies and electromechanical assemblies for a wide range of OEMs, including those in the commercial bus, truck, automotive, industrial automation and medical equipment industries.
Assembly in Action: Lockbolts Support 7,500 Thermosolar Collectors
January 26, 2009
Each collector had to be mounted precisely to ensure a high-level of thermal efficiency. The framework also has to be robust enough to withstand decades of vibrations from high winds and temperature variations.
Assembly in Action: Conveyor Provides Cut-rate Precision
January 26, 2009
Founded in 1994, Arnold Machine Inc. (Tiffin, OH) manufactures automated assembly equipment for the automotive, appliance and heavy equipment industries.
Assembly in Action: New Workstations at Heart of ACD Renovation
January 26, 2009
Founded in 1984, Automated Circuit Design (ACD-Richardson, TX) provides a wide range of services, including printed circuit board design, fabrication, prototyping, testing, assembly and component procurement.
Leading Lean: Untangling Spaghetti
January 26, 2009
How you analyze a spaghetti diagram is crucial, because it is the understanding that matters; not the map.
Editorial: Looking Ahead
January 26, 2009
Forward-thinking companies need to plan now for where they want to be when the current recession ends. Waiting until they see the bottom will leave them way behind.
Fastening Threads: Dissecting the Nut Factor
David Archer
December 22, 2008
The nut factor, as defined in the equation T=KDF, is not derived from engineering principles. Instead, it is arrived at experimentally to make the equation valid.
Editorial: Failing Our Future
December 22, 2008
The good news is that American fourth and eighth grade students improved their math and science scores in 2007. The bad news is that they continue to lag behind their peers from top-performing Asian countries.
Assembly Innovations: New Process for Molding Auto Parts Uses Less Resin
December 19, 2008
Mazda Motor Corp. (Hiroshima, Japan) has developed a new plastic molding technology that substantially reduces the weight of plastic parts for vehicles. The technology lowers the amount of plastic resin
Previous 1 2 … 120 121 122 123 124 125 126 127 128 … 222 223 Next
