Automation Profiles: System Wraps, Trims, Welds Car Doors
May 20, 2009
T.A. Systems worked closely with the customer to optimize the product for assembly.
Moving Forward: St. Jude Medical Expands Carolina Assembly Plant
May 20, 2009
Medical device manufacturer builds new plant to meet demand for pacemaker components.
Editorial: Do As I Say...
May 20, 2009
The results are in from the latest National Assessment of Educational Progress.
Leading Lean: A Tool for Lean Thinking
May 20, 2009
A lean tool won’t make you a lean thinker any more than a paintbrush or a sax will make you Rembrandt or John Coltrane.
Fastening Threads: Nine Common Bolting Boo-Boos
David Archer
April 29, 2009
As with most endeavors where success can’t be measured by keeping score, a good job of engineering is often defined by not doing a bad job. In other words, the most direct measurement of successful joint design and assembly is a lack of joint problems. Here’s a brief look at the most common reasons why problems occur during joint design, joint assembly and troubleshooting.
Quality in Assembly: Even Humble Screws Get a Battery of Quality Checks
April 28, 2009
The quality checks start before a single fastener is even produced.
Automation Profiles: Dial Assembles Disposable Dispensers
April 28, 2009
Various sensors ensure that parts are present and correctly oriented. A leak tester checks the final assembly.
Assembly in Action: Waterproofing a Space Robot
April 22, 2009
Engineers have had to figure out a way to adequately maintain the station given that the number of supply missions has been considerably reduced following the Space Shuttle Columbia disaster in 2003.
Assembly in Action: Sensors Error-Proof Cap Assembly
April 22, 2009
Recently, MPC upgraded its oil-cap assembly machine by substituting a machine-vision inspection system to take the place of the traditional tool and sensor technology it had been using previously.
Assembly in Action: ‘Milfords' Keep Knives Working
April 22, 2009
On these and several other products, Buck Knives uses no other means of attaching the two pieces together: There is no adhesive, only the two or three rivets inserted and rolled by the Milford riveter.
Previous 1 2 … 116 117 118 119 120 121 122 123 124 … 222 223 Next
